Condensation On Inside Of Old Windows - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 04-17-2012, 04:55 PM   #1
Rewards Points: 160
Condensation on inside of old windows
I need to replace my windows...but need them to last 2 more years due to financing...
I will put shrink wrap on em...they are double panes, on the inside window pane I was thinkin of recaaulking inside and outside of that window pane...then the outside window pane I was going to replace the metal trim that it sits in...finally, since the windows are wood, I was going to put water seal that is used for out side decks and let it soak into the wood.
i think its a good plan...comments???
hellothere123 is offline   Reply With Quote
Old 04-17-2012, 08:26 PM   #2
Rewards Points: 240
do they leak air ?
Fix'n it is offline   Reply With Quote
Old 04-18-2012, 12:40 AM   #3
Rewards Points: 14,312
That's a whole lot of work, time and money for an old window.
Condinsation on the inside can be caused by the humity level is to high in the house.
Things that can cause this are no fan in the bathroom of not running it long enough, running a gas heater of logs that are direct vented without opening a window slightly.
Old 04-18-2012, 08:10 AM   #4
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 5,564
+1
What you will likely find is that despite your best efforts, most older windows will still leak air and foster condensation.
Get the humidity level in the home down and that will mitigate your issues.
Do not put and exterior water sealant on the interiors of your window. It is not intended for that purpose and there may be off-gassing as a result that creates and unsavory and unhealthy living environment.
Have you considered a good air tight interior or exterior storm?
Condensation on new vinyl windows jimleahman Windows and Doors 12 02-22-2012 01:17 PM
Moisture inside large windows mibson Building & Construction 5 02-13-2011 01:25 PM
Condensation inside wall on vapour barrier rovers1973 Building & Construction 1 05-14-2010 10:00 PM
Replacing windows from the inside RosenKen Remodeling 3 08-06-2009 12:27 PM
Condensation on New Windows javan General DIY Discussions 4 11-04-2008 07:21 AM
