Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Windows and Doors
Old 12-01-2012, 10:40 AM   #1
condensation
I have a single window about 3ft square, in the living room of an old farmhouse. It's a hinged single-glass paned "door" and nearly airtight. I framed out a plexi panel about 6 inches behind it for insulation purposes and that's pretty tight too. Lots of moisture gathers on the inside of the plexi with no moisture on the "interior" paned door. Is there a way to prevent all that moisture inside the "pocket" I created. The only real issue with it is that we frequently can't see through it. Thanks.
kentannenbaum is offline   Reply With Quote
Old 12-03-2012, 09:12 AM   #2
Exterior Construction
Windows on Wash's Avatar
condensation
Tighten up the interior panel or loosen up the exterior panel.
Moisture is getting through to the outside panel and condensing (obviously). You need to lessen the moisture getting through or give it a path out (via air circulation) once it does.
Old 12-03-2012, 09:36 AM   #3
condensation
I'll give it a look. The inside paned window is a tightly hinged door and the plexiglas I installed last week those 6 inches away is glued to a frame I made with tight tolerances and crack/peal weatherstripping along all the edges. It's that outside "window" I'd much rather loosen up and am guessing it's on the upper side I ought to do it as that's where it's protected from the northeast elements where I'm located. Perhaps removing the weatherstripping along the top side will do it. Anyway, thanks for the tip. Much appreciated!
Condensation on new vinyl windows jimleahman Windows and Doors 12 02-22-2012 02:17 PM
Really Condensation? Or is it a Leak? DTproject Plumbing 6 02-21-2011 08:01 PM
condensation leak with metal roof on cathedral ceiling in Canada Serialrenovator Roofing 10 02-02-2010 01:18 AM
Moisture on windows baum Building & Construction 56 12-22-2009 06:39 PM
Sweating windows big daddy-o General Discussion 15 01-06-2008 03:41 PM
