Concrete Door Sill Question - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 05-22-2012, 12:19 PM   #1
DJD
Master DIY
DJD's Avatar
Question
Hi there, I've removed my 5ft patio door, and eventually will replace it with a vinyl sliding door.
I've removed an old PT door sill. It was tared over brick to attach it to the house. I am pretty sure that was installed wrong.
I've removed the old tar before the picture was taken.
I want to add a limestone door sill, which is pictured. The brick is above the ledger.
Now my question is how do I add the stone in? I was going to add some mortar between the brick and stone, but how to i attach it to the wood joists?
I was planing on shimming the stone on the wood joists to have proper drainage slope, but how would you attach the stone to the wood? I would put blue skin over the wood before the stone also. The stone will have a about 2" of overhang.
Also when the limestone is in, do I need to put a vapour barrier around the stone?
Thanks.
DJD is offline   Reply With Quote
Old 05-22-2012, 11:31 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 878
No need for a vapor barrier around the stone.
Most folks would set a sill into a bed of mortar. The last think you want to do is poke a bunch of holes in it prior to setting it.
taking out existing insulation, concrete bolt question s002wjh Insulation 1 01-25-2012 05:37 PM
Concrete Footer/Foundation Question Jae Building & Construction 9 06-16-2011 11:43 AM
Quick Question on concrete board membrane zpmontog0947 Carpentry 5 09-22-2009 08:01 PM
Concrete Form Gap Question bjones Building & Construction 1 03-10-2008 07:32 PM
Concrete question Daniel O'Connor General DIY Discussions 1 11-22-2004 03:54 PM
