Concealed Door Hinges & Door Repair - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 03-17-2014, 06:01 PM   #1
Rewards Points: 45
I have a set of double doors that have these specialty concealed hinges. The issue is that the door they are mortised into is a veneered solid particle board. These have been installed 20+ years and have now done a number on coming loose, nothing for the screws to bite into. Concealed Door Hinges & Door Repair-image-3383120708.jpg Concealed Door Hinges & Door Repair-image-3530848676.jpg I want to "refurbish" the door so that I can get a few more years out of it. I plan on cleaning out the mortise and then putting in a solid block of wood that would be glued and screwed, then remortising the hinge back in. Concealed Door Hinges & Door Repair-image-665289951.jpg Concealed Door Hinges & Door Repair-image-2094821114.jpg I don't want to purchase a new door, not an option at this point. Can anybody offer up any further ideas that might beef up the hinge area?
RunningSparky is offline   Reply With Quote
Old 03-17-2014, 06:53 PM   #2
iminaquagmire's Avatar
Rewards Points: 338
Longer screws to start. You can also glue a couple toothpicks into the existing holes until they bottom out, then snap them off and then put in the longer screws. There is also a wood hardener product you can apply but this isn't really its intended application and I've never tried it on loose fill particle board like door fill but it might work. I think you'll be all set with the toothpicks and longer screws though.
iminaquagmire is offline   Reply With Quote
The Following User Says Thank You to iminaquagmire For This Useful Post:
RunningSparky (03-17-2014)
Old 03-17-2014, 07:42 PM   #3
Rewards Points: 2,634
I think you got the right idea. I would try to maintain the existing size/shape of the mortise and go an inch deeper, and put in a hardwood block shaped to fit. If you don't have a perfect Norm Abrams fit of your filler block, I would use epoxy to glue it in, it fills gaps better.
SPS-1 is offline   Reply With Quote
The Following 2 Users Say Thank You to SPS-1 For This Useful Post:
RunningSparky (03-17-2014), Windows on Wash (03-18-2014)
Concealed toilet closet bolts concealed Plumbing 1 07-27-2011 01:06 PM
Previously concealed box DIYnewbie9 Electrical 1 07-10-2010 04:02 PM
concealed bath/shower valve sachamorph Plumbing 7 01-19-2009 04:15 PM
Concealed Roof Guttering on a 1930s Solid Brick Home buzzer Roofing/Siding 2 11-19-2008 06:51 AM
Help fitting concealed shower valve beeen Plumbing 5 01-04-2008 10:54 PM
