Compression Vs Spring Bronze Weatherstrip - Windows and Doors - Page 2 - DIY Chatroom Home Improvement Forum
Old 12-16-2012, 12:47 PM   #16
Rewards Points: 119
Originally Posted by HomeSealed View Post
+1, just make sure that the paint is fully dried.
On the stops, a pic would help as it depends how it is set up. You can make it work one way or the other, you may just need to add wider stops at worst.
Finally gotten to that yesterday and was unable to install it: door stop is too narrow. Looks like I may need to have at least a 1 1/2 wide door stop there, or 2" preferably. As I mentioned earlier, one side of door stop is 3/4" and the other one is 1" wide. Top is 1" wide *with* the flagpole bracket in the way. So I may have to work around that.
So, I may have to replace the door stop first before I can install the weatherstrip. These things always turn out to be more laborious than one anticipates.
SM05 is offline   Reply With Quote
Old 12-17-2012, 09:20 AM   #17
Home Performance
HomeSealed's Avatar
Rewards Points: 712
Gotta love old houses .... It will be worth it when you don;t feel that cold air coming in anymore.
Replacement Windows, doors, siding, roofing, insulation, and BPI certified energy consulting, Building Analyst 5051322
www.HomeSealed.com
Replacement Windows Milwaukee
HomeSealed is offline   Reply With Quote
Old 12-20-2012, 05:09 PM   #18
Rewards Points: 119
Sorry for bringing it up up again... Having a hard time finding 1 1/2 wide door stop locally - it's all 1 1/4" wide. I was wondering if all in one solution, ie door stop *with* that same type of weatherstripping built in, would work better instead:
Wood and Vinyl Clad Foam Door Sets with Stop
Does that seem like it would work OK? Thanks!
Intermittant total compression loss? johnd393 Automotive Repairs 7 07-26-2014 11:08 AM
Garage Door Unbalanced - Adding Larger or Additional Spring? super20g Windows and Doors 24 05-29-2013 11:12 AM
Ever install a door spring on a 2 door? noquacks Automotive Repairs 19 09-17-2011 06:29 AM
Ceiling Anchoring of Compression Poles planar Building & Construction 1 08-07-2011 03:28 PM
Size of Garage Door Torsion Spring planet Carpentry 3 12-19-2010 03:29 PM
