11-04-2012, 10:40 PM
#2
Compression vs spring bronze weatherstrip
I've tryed dozens of differant ways of sealing up old doors.
Each one has it's draw backs.
The only one I've used and it works every time perfectly is this one.
http://www.homedepot.com/h_d1/N-5yc1...&storeId=10051
Just make sure the door is latched and the dead bolts thrown in the locked position when installing it.
Make sure to predill the holes.
Once adjusted there's 0 way air can get in.
11-04-2012, 10:52 PM
#3
Great! That's the same one as the last link in my original post. Glad to see you validating my research there.  Thanks for the installation tips and for taking time to reply. I appreciate it.
11-05-2012, 10:47 AM
#4
Windows & Remodeling
Can't tell from that pic, but if it is the little vinyl bulb deal, I don't care for it. You can actually get nail-on Q-lon kits like this https://encrypted-tbn3.gstatic.com/i...6wJ6QtGRO83n7Q
Same seal that you would have on a brand new fiberglass door.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. , To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. , To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. , To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. , To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
The Following User Says Thank You to HomeSealed For This Useful Post:
11-05-2012, 10:39 PM
#5
Originally Posted by HomeSealed
Thanks for the suggestion. Don't think I recall seeing Q-lon weather stripping at the local hardware store. Where do you normally get it from if you don't mind my asking? Thanks again.
11-06-2012, 08:54 PM
#6
Exterior Construction
The usually have it at the big box stores by us.
if not, I am sure Amazon has it.
http://www.amazon.com/Schlegel-Q-Lon...atherstripping
The Following User Says Thank You to Windows on Wash For This Useful Post:
11-06-2012, 09:13 PM
#7
Originally Posted by Windows on Wash
Thanks. I appreciate it.
11-20-2012, 12:02 AM
#8
http://www.amazon.com/M-D-Building-P...d_sim_sbs_hi_2
2 quick questions about the above types of Q-LON weatherstrip please. 1 - Would that stick to the painted door (I'm guessing no since it's foam and not vinyl, right)? And 2 - would 1" wide door stop be enough to install it on?
11-20-2012, 12:30 PM
#9
That stuff is pretty good about not bonding to paint.
Not sure on the second one without seeing the door.
11-20-2012, 01:11 PM
#10
+1, just make sure that the paint is fully dried.
On the stops, a pic would help as it depends how it is set up. You can make it work one way or the other, you may just need to add wider stops at worst.
11-21-2012, 09:18 AM
#11
Thanks guys. Door paint is old so doesn't sound like anything is gonna stick to it.
Pics for the left, right and top side of the front door attached. Door stop is white and door is black color. Thanks so much!
11-21-2012, 04:56 PM
#12
Should be just fine. Make sure to buy the white stuff so that it matches the jambs.
11-21-2012, 08:50 PM
#13
Great. Thank you for confirming it, on Thanksgiving eve at that.
The Following User Says Thank You to SM05 For This Useful Post:
11-22-2012, 01:01 PM
#14
HomeSealed has a collection of minionsat his home so he is relaxing on Thanksgiving while they cook and clean.
11-23-2012, 10:38 PM
#15
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
