-   Windows and Doors (http://www.diychatroom.com/f104/)
-   -   Compression vs spring bronze weatherstrip (http://www.diychatroom.com/f104/compression-vs-spring-bronze-weatherstrip-162221/)
SM05 11-04-2012 09:21 PM
Hi guys,
Looking into weatherstripping old front door in my 100 year old house. Also trying to get it as air tight as possible to help with the street noise problem. We currently have old bronze type weatherstrip, which isn't performing well:
http://www.amazon.com/M-D-Building-P...dp/B000FP8MAA/
I was thinking about installing spring bronze one but am not sure how well it's gonna seal it and if it's good soundproofing wise. Looking into something like this:
http://kilian.stores.yahoo.net/114sprinbron.html
Alternatively I could go with compression weathersripping instead:
http://www.amazon.com/M-D-Building-P...dp/B0006VAMOC/
or
http://www.amazon.com/M-D-Building-P...dp/B0006VAMUG/
Any suggestions as to which one would work better? I'd appreciate any advice I can get. Thank you.
joecaption 11-04-2012 09:40 PM
I've tryed dozens of differant ways of sealing up old doors.
Each one has it's draw backs.
The only one I've used and it works every time perfectly is this one.
http://www.homedepot.com/h_d1/N-5yc1...&storeId=10051
Just make sure the door is latched and the dead bolts thrown in the locked position when installing it.
Make sure to predill the holes.
Once adjusted there's 0 way air can get in.
SM05 11-04-2012 09:52 PM
Great! That's the same one as the last link in my original post. Glad to see you validating my research there. :) Thanks for the installation tips and for taking time to reply. I appreciate it.
HomeSealed 11-05-2012 09:47 AM
Can't tell from that pic, but if it is the little vinyl bulb deal, I don't care for it. You can actually get nail-on Q-lon kits like this https://encrypted-tbn3.gstatic.com/i...6wJ6QtGRO83n7Q
Same seal that you would have on a brand new fiberglass door.
SM05 11-05-2012 09:39 PM
Thanks for the suggestion. Don't think I recall seeing Q-lon weather stripping at the local hardware store. Where do you normally get it from if you don't mind my asking? Thanks again.
Windows on Wash 11-06-2012 07:54 PM
The usually have it at the big box stores by us.
if not, I am sure Amazon has it.
http://www.amazon.com/Schlegel-Q-Lon...atherstripping
SM05 11-06-2012 08:13 PM
Thanks. I appreciate it.
SM05 11-19-2012 11:02 PM
http://www.amazon.com/M-D-Building-P...d_sim_sbs_hi_2
2 quick questions about the above types of Q-LON weatherstrip please. 1 - Would that stick to the painted door (I'm guessing no since it's foam and not vinyl, right)? And 2 - would 1" wide door stop be enough to install it on?
Windows on Wash 11-20-2012 11:30 AM
That stuff is pretty good about not bonding to paint.
Not sure on the second one without seeing the door.
HomeSealed 11-20-2012 12:11 PM
+1, just make sure that the paint is fully dried.
On the stops, a pic would help as it depends how it is set up. You can make it work one way or the other, you may just need to add wider stops at worst.
SM05 11-21-2012 08:18 AM
Pics attached
3 Attachment(s)
Thanks guys. Door paint is old so doesn't sound like anything is gonna stick to it.
Pics for the left, right and top side of the front door attached. Door stop is white and door is black color. Thanks so much!
HomeSealed 11-21-2012 03:56 PM
Should be just fine. Make sure to buy the white stuff so that it matches the jambs. :)
SM05 11-21-2012 07:50 PM
Great. Thank you for confirming it, on Thanksgiving eve at that.
Windows on Wash 11-22-2012 12:01 PM
HomeSealed has a collection of minionsat his home so he is relaxing on Thanksgiving while they cook and clean.
:laughing:
HomeSealed 11-23-2012 09:38 PM
1 Attachment(s)
:laughing:
:yes:
