Composite Exterior Door - Stain Peeling! - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 03-19-2012, 06:06 PM   #1
Rewards Points: 83
Composite exterior door - stain peeling!
Hi,
Our composite material front entry door is about a year old and was stained brown less than a year ago (we closed in July 2011, so it was probably stained in April, May, or June...cant remember). This morning I noticed the stain is peelings in various areas. I didnt notice this until today and certainly not during our "winter", if you could call it truly winter. Anyway, I am curious what is causing the peeling, and also if anyone thinks we might be able to look to the contractor for help with it.
Thank you!
darthsmozers is offline   Reply With Quote
Old 03-19-2012, 08:10 PM   #2
Home Performance
HomeSealed's Avatar
Rewards Points: 712
Most stain finishes have a warranty for a good 5 or 10 years, so you should be able to take advantage of that. That is assuming that this was a factory stain finish. If it was done on-site by your contractor, there will be no manufacturer warranty, only whatever was specified by him/her... I'd definitely make the installer the first point of contact.
Replacement Windows, doors, siding, roofing, insulation, and BPI certified energy consulting, Building Analyst 5051322
www.HomeSealed.com
Replacement Windows Milwaukee
HomeSealed is offline   Reply With Quote
Old 03-20-2012, 01:58 AM   #3
Rewards Points: 13,774
Never heard of a composite door, sure it's not fiberglass?
It's rare to see a stain peel, more likly someone tryed using poly over the stain, which should not have been done.
Any Fiberglass door I've seen is stained with Gel stain.
Old 03-20-2012, 09:39 AM   #4
Home Performance
HomeSealed's Avatar
Rewards Points: 712
I assume that "composite" is being used interchangeably with fiberglass. I've seen a few factory stain finishes wear through and/or peel around the door knob where it gets a lot of contact.
www.HomeSealed.com
Old 03-20-2012, 06:39 PM   #5
Rewards Points: 83
Fiberglass may be the correct term, sorry.
The peeling looks very random .... Mostly on the little "shelf" that is affixed beneath the window at the top of the door, but some on the main face of the door as well.
recurrent peeling paint on interior walls Krista2 Painting 14 09-10-2011 03:17 PM
Replacing deck with composite decking, good or bad? rjohnson84 Building & Construction 2 07-25-2011 12:00 PM
Small composite deck-which brand to go with? stormchaser Carpentry 11 05-24-2011 09:49 AM
Paint peeling issue MadMax99 Painting 6 12-18-2010 03:19 AM
Composite deck with wood railings? Or ditch the composite and go all wood? CoconutPete Building & Construction 5 07-29-2010 12:30 PM
