Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Windows and Doors
Old 08-23-2012, 04:29 PM   #1
composite doors?
Just doing some research on finishing my basement. Not sure what kind of doors to get. I was thinking of composite doors because they won't be as affected by humidity/water, and that sounds good for a basement?
Any feedback on that?
Amateuralex is offline   Reply With Quote
Old 08-23-2012, 04:53 PM   #2
composite doors?
If it's that humid It's going to be effecting everything not just the doors.
The ansewer is to run a dehumidifyer if that's a concern.
A dry basement can not have mold.
Those doors are going to cost far more.
Even a properly painted MDF door wil work if it's painted on all 6 sides.
Old 08-24-2012, 09:51 AM   #3
composite doors?
Thanks for the reply. It's not actually super humid down there, but probably more humid than the rest of the house. The composite doors I've looked at are actually cheaper than wood doors. I guess I don't understand what 'composite' means. They are MDF?
Old 08-26-2012, 06:57 PM   #4
Bombastic Idiot
notmrjohn's Avatar
composite doors?
Composite can be a misleading term. Wood is a natural composite of cellulose and lignin , adobe is a composite of straw and mud, MDF is wood fibers wax and resins. None of those are particularly water resistant. But when most people say composite they mean something made with a man made resin that most folks would consider to be a plastic or epoxy and designed and engineered to be resistant to water, weather, sun etc. So when buying "composites" make sure everybody is on the same page. Ahh, yes, paper is a composite.
notmrjohn is offline   Reply With Quote
Old 08-26-2012, 10:34 PM   #5
composite doors?
Cool ok that helps a bit. So to be specific, I'm looking at the Jeld-wen doors at the orange store. Any opinions about them?
Old 08-26-2012, 11:10 PM   #6
composite doors?
Just make sure the doors get removed and painted two coats of paint on all sides not just the faces.
I'm pretty sure eveyone's going to jump on me but I like to use an enamel paint on doors and trim. It's so tough it's even hard to sand. You can get it water based and in three differant sheens.
I use a 6" foam hot dog roller and a 2-1/2 sash brush for the details and touch up.
Laying the doors out flat helps it to self level and get no runs.
Old 08-27-2012, 02:48 PM   #7
Bombastic Idiot
notmrjohn's Avatar
composite doors?
Enamel is great, satin or semi-gloss won't show any imperfections glossy, specially if you're not a great painter. Joe's reminding us that a door has six sides. lots of folks forget those other two.
Made My Own Inexpensive Wood Garage Carriage Doors iffy Project Showcase 4 03-31-2012 03:07 PM
Repair or Replace Garage Doors??? jbird0005 Windows and Doors 2 12-10-2011 07:42 AM
Reality check on interior doors recently delivered PatBB Carpentry 8 09-05-2011 06:36 PM
It's hot outside. Keep the exterior doors and windows closed if running the A/C? Taylor Crockett HVAC 3 07-07-2008 06:04 PM
