Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Windows and Doors
Old 10-23-2011, 05:00 PM   #1
cleaning gray film off exterior windows
is there a good, non-abrasive product to clean a gray spotty film off the exterior surface of my large window?
judy warren is offline   Reply With Quote
Old 10-23-2011, 08:35 PM   #2
Exterior Construction
Windows on Wash's Avatar
What surfaces? Glass, frame, etc?
Is there a window screen on the window? If so, what material is it made of?
If the screen is aluminum, that gray film is usually oxidation from the aluminum and cleans off very easily.
If the spotting is in the painted surface, it is often mold and requires a bit more effort to get it off. In some cases, it is coming from behind the finished surface and is impossible to clean.
Old 10-24-2011, 07:37 AM   #3
vinegar and water was the old standby, Windex, and others should also work fine.
can bad cleaning destroy your furnace eolsunder HVAC 1 09-22-2011 03:52 PM
Window shrink film around sill? Liv2123 General Discussion 4 01-31-2011 09:10 PM
Shrink film window insulation, no kit EscarHolmez General Discussion 3 12-28-2008 01:05 PM
Shrink Film Window Insulation miserlou General Discussion 10 11-24-2008 07:19 AM
oil base paints NoExperience Painting 30 09-04-2008 06:37 AM
