Champion Windows Issue - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 05-01-2014, 10:53 AM   #1
Rewards Points: 16
Champion windows issue
Metal framed windows and I don't know the name of the part. Specifically went to open the window and heard twang!
Left and right side metal lift assisters both disconnected and sprung, so to speak.
So are these broken or do they just need to be wound back up and attached? If yes which way and how to adjust?
digitalplumber is just a name for use here, I am not a plumber!
digitalplumber is offline   Reply With Quote
Old 05-03-2014, 08:58 PM   #2
Rewards Points: 124
Spring balances; and if you heard a twang one of them probably broke. Inside there is a spring which never breaks, nylon cord, a little block and tackle pulley, and a rivet holding one end of the spring, all of which can break. They generally can't be fixed, but several companies sell replacement spring balances. Google 'champion window parts'.
On the other hand if the spring balance has popped up above the moving sash, the cam that is attached to the sash may have broken. The twang tends to point to the spring balance.
ChuckF. is offline   Reply With Quote
The Following User Says Thank You to ChuckF. For This Useful Post:
digitalplumber (05-04-2014)
Old 05-03-2014, 11:13 PM   #3
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 898
Are they spiral, constant force, side load, or block and tackle.
Something broke to be certain but what depends on which system.
Post up a picture.
Old 05-04-2014, 01:08 AM   #4
Rewards Points: 16
Post up a picture.
Spiral in their own round tube. Green Tip with a hook.
Old 05-07-2014, 11:24 AM   #5
Rewards Points: 898
Most spiral balances will break in either the balance tube or the clutch/shoe assembly.
Check where the pivot pin mounts to the window and look for broken plastic.
Old 05-07-2014, 02:48 PM   #6
Rewards Points: 16
Thanks, just got 4 new balances. Do these go straight in without any adjustments?
Old 05-09-2014, 11:51 AM   #7
Rewards Points: 898
They need to be coiled and pre-tensioned.
Buy the little tool. It will save you heartache.
http://www.amazon.com/CRL-Window-Spiral-Balance-Tensioning/dp/B000KZYGAA
Old 05-10-2014, 07:47 AM   #8
Rewards Points: 16
Thanks have the tool now I need instructions for what you describe?
Old 05-11-2014, 11:57 AM   #9
Rewards Points: 898
Replace original windows myself? SuperJETT Windows and Doors 13 04-27-2015 03:19 PM
Worthwhile to replace old wood frame basement windows with new vinyl windows? Cost? TomServo Windows and Doors 5 10-25-2012 08:10 AM
Replace just two windows - dumb idea? ChrisJJ Windows and Doors 13 06-01-2012 11:31 AM
Any restitution for VERY late windows? msbriggs Building & Construction 21 10-05-2010 07:25 AM
Replacing Vinyl Windows w/o Nailing Fin irish Building & Construction 1 06-03-2010 11:37 AM
