Chamberlain Belt Drive Spring Tensioner - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 05-26-2013, 07:53 PM   #1
Rewards Points: 93
Chamberlain belt drive spring tensioner
So I just bought a chamberlain wd832kev opener and was going to assemble the spring tensioner. The tensioner supplied looks different than the one in the manual. It almost seems that the spring assembly should go on the left side of the trolley tab without a lock washer and nut on the right. But since the directions that came with the tensioner say to release the spring I thought I'd ask before doing any releasing. Anyone else run into this?
Chamberlain belt drive spring tensioner-image-1759312735.jpg   Chamberlain belt drive spring tensioner-image-1541669117.jpg
scottyv81 is offline   Reply With Quote
Old 05-26-2013, 08:39 PM   #2
Remodeler
Rewards Points: 316
Can't make out the pic in the manual very well, but the pic of your tensioner looks like the way I have assembled them many times.
Here is a link to the PDF manual and it looks just as you have it assembled. Your manual is clearly different, you may have gotten a newer manual but an old style tensioner. I have not seen any like the one shown in your manual yet.
Just tighten the tensioner up finger tight, don't use any tools to tighten it, and the turn the ring to release the spring.
iamrfixit is online now   Reply With Quote
Old 05-26-2013, 09:39 PM   #3
Rewards Points: 93
Ok, makes much more sense, thanks!
Old 05-26-2013, 10:30 PM   #4
firehawkmph's Avatar
Rewards Points: 1,826
The tensioner in your pic is designed to properly tension the belt drives. Like Iam said, assemble the tensioner, belt, etc., then tighten up finger tight. Then you release the spring.
Mike Hawkins
firehawkmph is online now   Reply With Quote
garage door chain drive to belt drive pberm1962 General DIY Discussions 16 11-26-2011 09:28 PM
Snowblower Drive Belt IM2BZ2P General DIY Discussions 14 02-08-2011 11:28 AM
FWD Drive Belt Tension vabear Landscaping & Lawn Care 2 11-11-2010 10:40 AM
Belt care... RippySkippy Tools 3 12-25-2008 02:43 PM
Snow blower drive belt replacement help lwhiten395 General DIY Discussions 5 01-15-2008 04:14 PM
