Center Hinge On Exterior Door - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 12-06-2013, 01:49 PM   #1
Center Hinge on Exterior Door
How important is the center hinge on a residential exterior door?
I can see how the top one and the bottom one would help with keeping the door straight, but the center one seems completely worthless.
Talk some sense into me!
DIYcurious is offline   Reply With Quote
Old 12-06-2013, 02:37 PM   #2
Rewards Points: 13,450
A cheap door will only have two.
It helps spread out the load.
If there's only two all the weights on the top hinge and often times will pull out the screws.
Old 12-06-2013, 04:34 PM   #3
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,114
the third hinge also helps to reduce the chances of the door from warping
woodworkbykirk is offline   Reply With Quote
meter/main combo to load center grounds and bonding? ronsquery Electrical 2 03-16-2013 05:29 AM
Mahogany Door Jamb - What nails and where? Toronto Carpentry 25 07-26-2012 07:08 PM
Pre-Hung doors - How to Hang Willie T How To Guides 23 01-28-2011 09:24 AM
Ductwork Around Center Beam Build HVAC 6 06-16-2009 10:56 AM
hinge drill bit or center punch? Pawl Carpentry 7 03-26-2008 09:00 PM
