Caulking Vinyl Windows In Brick - Windows and Doors - Page 2 - DIY Chatroom Home Improvement Forum
Old 03-19-2012, 07:13 PM   #16
Tom Struble's Avatar
Rewards Points: 2,002
are the windows under an overhang?if so i don't think i'd be all that worried about it
Tom Struble is offline   Reply With Quote
Old 03-19-2012, 07:30 PM   #17
Rewards Points: 2,506
Originally Posted by rightit View Post
Short of ordering a new window, removing the brick, reinstalling the window and re-bricking, can anyone offer suggestions as to how to best solve the issue?
I use to have rowlocks for my window sills on the front brick veneer of my home. The mortar joints between the rowlocks leaked and without the proper flashing behind water ran under window and into house.
My solution was to eliminate the rowlocks for window sills and replace with limestone.
Caulking Vinyl Windows in brick-100_5954.jpg   Caulking Vinyl Windows in brick-100_6611.jpg   Caulking Vinyl Windows in brick-100_6660.jpg   Caulking Vinyl Windows in brick-2222.jpg   Caulking Vinyl Windows in brick-100_6654.jpg
hammerlane is online now   Reply With Quote
The Following 2 Users Say Thank You to hammerlane For This Useful Post:
HomeSealed (03-19-2012), rightit (03-19-2012)
Old 03-19-2012, 08:24 PM   #18
Rewards Points: 150
Hi Tom,
Great idea! The caveat is that I would need to replace all the sills on the front of the house, and I'm pressured to finsh this project (my office) before my busy season starts. That does seem like a great project for the near future, though. It also makes me feel a bit better about the current issue, as planning to replace all of the sills means that the current sill is temporary. I could live with that. Thanks!
And yes, the window is under an eve, but facing west in a stormy climate, so the sill is exposed to often heavy rain and wind.
Also, the good news in all of this is that I "super flashed" my window (and under the tyvek to the brick ledge), so if water does get it, it's not likely to get in the house:
rightit is offline   Reply With Quote
The Following User Says Thank You to rightit For This Useful Post:
Tom Struble (03-19-2012)
Old 03-20-2012, 12:01 AM   #19
thing is i don't think the small amount of caulk your going to be able to get into that narrow crack is going to do much for you,proper caulk width for quad would be 1/4-3/8'' over backer rod
you can do the metal flashing if it makes you feel better,lead would probably be best as it's easier to ''dress'' it down tight to the brick
The Following User Says Thank You to Tom Struble For This Useful Post:
rightit (03-20-2012)
Old 03-20-2012, 06:57 PM   #20
Rewards Points: 150
Thanks so much to those who contributed. Due to my schedule, I wound up taking the simplest route. I stuffed backer rod into the gaps and troweled mortar over them. Then I mortared in the brick I removed. It came out fine. I'll be on a job the next few days, but hope to wash the brick Fri. or Sat, after which I'll caulk. OSI Quad and Flex 9000 seem to be the caulk of choice. If there's no reason to pick one over the other, I'll just pick up some Quad from Lowes. I appreciate all the information and learned a lot from your responses. Thank you!
Pella Windows - Serious Frost Issue snowman72 General DIY Discussions 22 07-08-2011 01:39 AM
Caulking Vinyl Clad window to Brick screwy Windows and Doors 2 04-28-2011 08:00 AM
Exterior Caulking Suggestions for painted trim to vinyl windows? Learn2Build General DIY Discussions 1 06-04-2010 01:44 PM
Replacing Vinyl Windows w/o Nailing Fin irish Building & Construction 1 06-03-2010 11:37 AM
Vinyl Replacement Windows fixiechick General DIY Discussions 56 04-20-2009 06:37 PM
