Caulking Inside Of Double Pane Windows. - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 06-22-2012, 06:07 PM   #1
Caulking inside of double pane windows.
We are getting wind driven rain in our walls from the windows above. We are having the outsides caulked and waterproofed but can we caulk the sash as well. Inside the window itself? We can't pay for new windows now.
Shanti is offline   Reply With Quote
Old 06-22-2012, 06:09 PM   #2
Pane not pain lol!
Old 06-22-2012, 06:35 PM   #3
Rewards Points: 12,882
If someone caulks the sashes there's no way to open and close the window.
Post some pictures of these windows. If there double glazed it's more likly it may need reglazing, not recaulking.
Old 06-22-2012, 07:42 PM   #4
Here's the photo. The masonry guy said water might be entering from this space between the screen and window. I'm hoping that is impossible.
Old 06-22-2012, 07:52 PM   #5
Tom Struble's Avatar
Rewards Points: 2,002
look for weep holes or slots on the outside bottom,they may be caulked over
Tom Struble is offline   Reply With Quote
The Following 2 Users Say Thank You to Tom Struble For This Useful Post:
kwikfishron (06-22-2012), oh'mike (06-22-2012)
Old 06-22-2012, 08:00 PM   #6
So water cannot be entering through the inside? When there is driving rain that is.
Old 06-22-2012, 08:25 PM   #7
Remove the screens and clean those windows.
There so full of trash there's no way they can drain.
If those windows were installed correctly there would be no reason for any caulking.
Plugged up drain holes, no window tape around the window flanges, J moulding installed wrong, can all cause windows to leak.
Old 06-22-2012, 08:25 PM   #8
kwikfishron's Avatar
Rewards Points: 92
We need pictures from the other side of the window too.
kwikfishron is online now   Reply With Quote
Old 06-23-2012, 10:10 AM   #9
if it is a welded unit and the weeps are clear then i don't see how it could leak between the screen and the window,but i see water staining on the inside stool
Old 06-23-2012, 11:03 PM   #10
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 906
Clean the sills and flush out the weep tracks.
Make sure they are not painted over as also mentioned.
cleaning double pane tinted home windowq M.G Abernathy Windows and Doors 1 05-01-2012 07:39 PM
Condensation on inside of old windows hellothere123 Windows and Doors 3 04-18-2012 09:10 AM
Dual Pane Windows No Low E Glass and No Argon Gas Filling AZSun Windows and Doors 4 08-12-2011 10:10 PM
double pane windows bobbroadley Windows and Doors 4 03-05-2011 11:36 AM
Vinyl Replacement Windows fixiechick General DIY Discussions 56 04-20-2009 06:37 PM
