Caulking Exterior Trim To Windows - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 03-31-2014, 11:13 AM   #1
Caulking Exterior Trim to Windows
I am in the process of replacing some exterior window trim and wondering what the correct process is in terms of caulking between the window and trim. I was planning on caulking between the window and trim on the left/right vertical pieces as well as on the bottom (against the window itself, not the bottom of the bottom board). The top sits on flashing or drip cap that folds over the window so I wasn't planning any caulking on the top.
The boards I am replacing were caulked the same way. I'm wondering if there's any weep holes or anything in the window body that may have been covered up by the previous job that I should be looking out for. The windows are Anderson Slim Line and when I called Anderson asking for installation docs they said they were discontinued and no longer could give out the info
Thanks!
eclipsis is offline   Reply With Quote
Old 03-31-2014, 02:42 PM   #2
Home Performance
HomeSealed's Avatar
Rewards Points: 712
Sounds like you are on the right track, but some pics would help.
Replacement Windows, doors, siding, roofing, insulation, and BPI certified energy consulting, Building Analyst 5051322
www.HomeSealed.com
Replacement Windows Milwaukee
HomeSealed is offline   Reply With Quote
Old 03-31-2014, 05:50 PM   #3
Rewards Points: 13,712
We have no idea what trim your using.
How the windows where installed.
What type siding you have.
"Drip caps" do you mean nailing flanges?
Was there window and door tape used?
Worthwhile to replace old wood frame basement windows with new vinyl windows? Cost? TomServo Windows and Doors 5 10-25-2012 07:10 AM
New windows and siding - my experience Marty1Mc Windows and Doors 0 08-05-2012 08:29 AM
Caulking inside of double pane windows. Shanti Windows and Doors 9 06-23-2012 10:03 PM
Caulking Windows of a home with vinyl siding BabyFace Windows and Doors 4 06-14-2012 01:27 PM
Pella Windows - Serious Frost Issue snowman72 General DIY Discussions 22 07-08-2011 12:39 AM
