Caulking Door Way (outside) - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 10-03-2011, 03:48 PM   #1
caulking door way (outside)
need to get a clean cut line ( how do I)
my tape will not stick to the brick...and I'm afraid the caulk line
will look sloppy?
buckeyeme is offline   Reply With Quote
Old 10-03-2011, 03:54 PM   #2
AGWhitehouse's Avatar
Practice first on some scrap or in inconspicuous areas. Or use clear caulk
Life's too short...so enjoy it!
AGWhitehouse is offline   Reply With Quote
Old 10-03-2011, 04:01 PM   #3
caulking wood door frame on brick wall
After old caulk removed - too big a gap for clear caulk. . . in my opinion.
Old 10-03-2011, 04:04 PM   #4
kwikfishron's Avatar
Rewards Points: 774
How big of gap?
What type of caulk?
You want a polyurethane based caulk if it’s going against brick.
kwikfishron is offline   Reply With Quote
Old 10-03-2011, 04:06 PM   #5
Framing Contractor
Rewards Points: 120
If the gap is too large, installing a small moulding may solve most of your problems.
sixeightten is offline   Reply With Quote
Old 10-05-2011, 12:11 PM   #6
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 5,244
Stucco tape and caulk will give you the finest lines.
Caulking a Bathtub, need advice RealMarkP Plumbing 5 03-12-2011 05:25 PM
caulking tile backsplash--he sprayed something on the caulking then used his finger Limit54 Tiling, ceramics, marble 6 12-06-2010 05:45 PM
Caulking Exterior Windows unixb0y Painting 1 06-04-2009 05:31 PM
Where stucco meets the window & door; caulking Longleaf Building & Construction 12 08-12-2008 04:46 PM
Tuckpointing vs. Caulking NewUser1 Building & Construction 2 07-09-2008 08:33 AM
