Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Windows and Doors
Old 10-24-2012, 01:13 PM   #1
Which caulk to use on outside north facing window?
I am replacing the caulk around my window because the installer from the previous owner/s did not do a good job caulking around the aluminum capping. There are gaps in the caulking. I noticed a bit of water coming through when I took off the trim on the inside while doing a room renovation.
I think whoever did the vinyl windows used silicone on the inside of the capping and whoever did the vinyl siding Outside of capping connected to J clips(?)used a different kind that is much harder and seems like it would stand up to weather a lot better but there was gaps in it.
I went to my local home store and picked up OSI Quad for window. Is this the correct kind to use or would be Silicone be better? Note that this window gets all the storm weather.
Thank you in advance
Elkypro is offline   Reply With Quote
Old 10-24-2012, 05:25 PM   #2
Exterior Construction
Windows on Wash's Avatar
Quad is good stuff but somewhat difficult to work with if you haven't used it before. Do some test application on a flat board so you get used to it.
The Following User Says Thank You to Windows on Wash For This Useful Post:
Elkypro (10-25-2012)
Old 10-24-2012, 05:33 PM   #3
Moderator
kwikfishron's Avatar
and....be sure to have a rag and some thinner close by.
-NEW MEMBERS-
Please include your basic location in your profile. Some of the answers given are specific to a Region or State.
kwikfishron is online now   Reply With Quote
Old 10-24-2012, 07:07 PM   #4
Difficult to use as in it comes out of the tube differently? Or just how it lays down?
Old 10-24-2012, 07:27 PM   #5
Both.
Each sealant is different so get and extra tube to practice with and make sure the temperature on the tubes are consistent.
Old 10-24-2012, 07:33 PM   #6
Moderator
I'd suggest a decent caulking gun. There's a HUGE difference between a 3 and a 17 dollar gun.
Once you've used a decent gun you'll never go back to a cheapo again.
-NEW MEMBERS-
The Following User Says Thank You to kwikfishron For This Useful Post:
woodworkbykirk (10-28-2012)
Old 10-28-2012, 10:07 PM   #7
journeyman carpenter
woodworkbykirk's Avatar
quad is definitely a better product than silicone. the problem with using silicone is that it wont stick to a dirty surface or anything with old caulking residue and be expected to actually stay there. ive seen more caulking jobs fail that were done with silicone than with a poly butyl type caulking
woodworkbykirk is offline   Reply With Quote
Old 10-29-2012, 09:57 AM   #8
Thanks. I used the quad and it seemed to feel like a better product.
Old 10-29-2012, 11:00 AM   #9
Windows & Remodeling
HomeSealed's Avatar
Quad is a high end caulk and is great for that application. You should be in good shape for a while.
HomeSealed is offline   Reply With Quote
Old 10-29-2012, 12:03 PM   #10
the quad did go on a bit differently like some had said it would. It was cold outside as well as the cold metal. It's not the prettiest job but will last until I replace the windows.
Window Stool Removal Issue bperk21 Windows and Doors 4 04-21-2011 07:03 PM
Stinky Caulk around window. Only when cold outside and receives direct sun. mvigadi Building & Construction 1 12-08-2010 01:01 PM
my fix for rotting outside sill on wooden window guest General Discussion 6 11-06-2010 03:58 PM
Re-sizing a window opening shtoink Carpentry 5 09-04-2008 11:47 AM
