Caulk New Construction Windows Or Not? - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 08-16-2012, 09:20 AM   #1
Caulk new construction Windows or not?
Hello everyone.
My framers just finished framing our house, which my wife and I are working on finishing ourselves. When they installed the windows they didn't caulk the nailing fins - just leveled, plumbed and nailed. They told me to use tape, or protecto-wrap. I was surprised by this. Normal?
Jeff
aquasport17 is offline   Reply With Quote
Old 08-16-2012, 10:23 AM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 1,770
Best practice would be to lay a beading bead of sealant on the back of the flange at the jamb sides and head, then install, then tape.
Don't caulk the bottom part of the flange.
Sealing it up with tape will do just fine but the caulking is a nice little added layer of protection in my opinion.
Make sure you spray foam from the interior to air seal but again, don't over fill the bottom or you can trap water in the wall.
Old 08-16-2012, 10:38 AM   #3
Excellent. Thank you. What tape do you recommend? The protecto tape is quite expensive. No opposed to doing it right though.
Old 08-17-2012, 07:53 AM   #4
The tapes are not cheap but neither is re-doing it.
We normally use the Tyvek system on new construction installations.
Old 08-18-2012, 12:48 AM   #5
Registered User
Rewards Points: 5,204
1. Is there a water restrictive barrier on yet- housewrap or building paper?
2. What type of siding?
3. Did they install a pan flashing yet?
If building paper; http://www.buildingscience.com/docum...researchreport
Be careful with the flashing tape; http://www.buildingscience.com/docum...gement-details
Gary
Old 08-18-2012, 07:19 AM   #6
Home Performance
HomeSealed's Avatar
Rewards Points: 710
As WoW said, the caulking would be best and give an additional layer of protection, however if they are already in, you should be fine with the tape/wrb(housewrap)/flashing all lapped properly. If you are DIY this stage, make sure that you read up on it as it is extremely critical that it is done properly. Gbr has some links there, and you'll find a lot of other good info on that site as well... I'm guessing that they did not install a pan flashing either, but again, that would just be one more level of CYA. The only pan flashing that I have ever seen in person are those that my own guys installed.
Replacement Windows, doors, siding, roofing, insulation, and BPI certified energy consulting, Building Analyst 5051322
www.HomeSealed.com
Replacement Windows Milwaukee
HomeSealed is offline   Reply With Quote
Replacement vs New Construction Windows skirider Windows and Doors 8 05-27-2012 04:18 PM
Installing new construction windows in old House Fisher252 Windows and Doors 11 10-10-2011 05:01 PM
How to Clean Up Caulk Mess on Driveway Left By Construction Crew ToolbeltGal Building & Construction 6 09-25-2010 05:36 PM
New construction windows cable911 Building & Construction 5 07-10-2009 09:50 PM
Caulk Windows eric s General DIY Discussions 2 11-26-2006 09:45 PM
