Casement Window In New Construction - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 01-12-2012, 11:03 PM   #1
gkaro's Avatar
Hi I will undertake the install of two new casement windows in new 2x6 construction. Size is 42x70.
The exterior will be a wooden or composite siding. I assumed that the Windows are made differently depending on the exterior finish...ie brick or siding...
The window supplier said that all I need to do is buy some j trim from the depot and use on their Windows for siding.
I can't understand how the window,siding and j trim all fit together for a no leak window.....
Any help, diagrams woukd help...
Thanks.
gkaro is offline   Reply With Quote
Old 01-12-2012, 11:10 PM   #2
Rewards Points: 2,212
Wood and composite siding are usually caulked to the brickmould, No J trim.
Read this thread - It is on vinyl siding but has good info on properly installing windows.
http://www.diychatroom.com/f19/pathe...t=vinyl+siding
mae-ling is offline   Reply With Quote
Old 01-12-2012, 11:20 PM   #3
Disabled wood vet
titanoman's Avatar
Rewards Points: 1,004
If it needed j mold to be flashed right or something it should come with it you would think.
Sent from a Samsung Galaxy SII
titanoman is offline   Reply With Quote
Old 01-13-2012, 05:46 AM   #4
gkaro's Avatar
Thanks guys
Old 01-13-2012, 12:52 PM   #5
Home Performance
HomeSealed's Avatar
Rewards Points: 712
The comment above is correct. You won't use j trim with wood or composite siding (at least not most composites).
As it was explained on that other thread, layering correctly is key. I like to make a sill pan with window tape, then install the window. Wrb goes over the top flange (and over the tape). I usually caulk the back side of the flange as well for extra protection. On the bottom, the flange sits on top of the Wrb.
Replacement Windows, doors, siding, roofing, insulation, and BPI certified energy consulting, Building Analyst 5051322
www.HomeSealed.com
Replacement Windows Milwaukee
HomeSealed is offline   Reply With Quote
Old 01-13-2012, 01:20 PM   #6
gkaro's Avatar
What is wrb??
Old 01-13-2012, 01:27 PM   #7
Disabled wood vet
titanoman's Avatar
Originally Posted by gkaro
What is wrb??
You can use felt paper
Old 01-13-2012, 03:06 PM   #8
Just learnt this WRB is Weather Resistant Barrier - House wrap
Old 01-13-2012, 04:43 PM   #9
Home Performance
HomeSealed's Avatar
Rewards Points: 712
Mae ling is correct.
... In the olden days, felt was used as house wrap.
www.HomeSealed.com
Old 01-18-2012, 08:10 PM   #10
gkaro's Avatar
Went to the depot to see what you guys are talking about. The window guy showed me two types of brick mould. One a straight 1.5" brick mould and the other was called a brick mould with what looked like a built in j trim.....he didn't know much. The first one doesn't look like it had a nailing flange.
Which is correct for wood siding.
Old 01-18-2012, 08:29 PM   #11
Rewards Points: 13,960
Are you sure you do not want to hire someone to install these for you?
This is one place you reall do not want to mess up.
Old 01-18-2012, 08:35 PM   #12
gkaro's Avatar
Unfortunately....can't.
I've installed many Windows with alum capping...just never with siding.
Old 01-18-2012, 08:56 PM   #13
Why wood or composite siding and not vinyl?
Lots harder to install and maintain both wood and composite.
Old 01-18-2012, 09:00 PM   #14
gkaro's Avatar
its low. Do not like the "softness" of vinyl where it can be touched at ground level...
casement window leaks kel Building & Construction 0 06-27-2010 07:02 PM
Window replacement Help (New Construction) gregt848 Building & Construction 3 10-18-2009 06:59 PM
Problem with window and everything around it malfunction Building & Construction 3 05-26-2009 05:11 PM
Old window header construction Theresa Building & Construction 5 11-03-2008 02:57 PM
RO size vs. window unit size, new construction BigJimmy Building & Construction 3 01-02-2008 07:34 AM
