carpentry: How To Level & Plumb An Exterior Door?
You can use cedar shims.
Firs i level the head of the door and shim bottom to make level.
Then If the side frame jambs are close to plumb I center the top with shims and nail.
Then i adjust bottom side to side to get the reveal at the top of the door perfect. Shim and nail.
Exterior door you can hide a screw or nail behind the weather stripping.
If my advise helped you hit "Thanks" To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
