Cannot Figure Out How To Remove Door Handle - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 02-11-2013, 01:29 PM   #1
Unhappy
Cannot figure out how to remove door handle
Hi, I've got an old door handle and I can't seem to figure out the mechanics of how to remove it. I'm planning on replacing it with a locking handle. So far I've removed the two screws on the side, but the panel won't come off. I've looked all around the handle, and on the outer side only, there is a little metal slot that when pushed in with a screwdriver, allows one handle to come off. The other side has no such slot. However, when looking through the tube from the removed handle, I can see small metal tabs on the other side that look like they hold that handle on. I can't push them down though, with any tool I've tried. I'm not an expert, but I've replaced several door handles before, and this one has me completely stumped!!
Cannot figure out how to remove door handle-20130211_100613.jpg   Cannot figure out how to remove door handle-20130211_100711.jpg   Cannot figure out how to remove door handle-20130211_100720.jpg   Cannot figure out how to remove door handle-20130211_100649.jpg   Cannot figure out how to remove door handle-20130211_100653.jpg
ercussio is offline   Reply With Quote
Old 02-11-2013, 01:56 PM   #2
Not so new
12penny's Avatar
Rewards Points: 520
The white escutcheon plate will have to be pryed off
gently. There's screws behind it.
12penny is offline   Reply With Quote
The Following User Says Thank You to 12penny For This Useful Post:
oh'mike (02-11-2013)
Old 02-11-2013, 02:04 PM   #3
Rewards Points: 13,274
Look close at the trim ring, there's a tiny rectanguler hole, that's where it pops off.
The knob had the same set up.
sixeightten (02-11-2013)
Old 02-11-2013, 02:05 PM   #4
Registered User
Rewards Points: 5,216
Score the paint seal around it first (utility knife), use a slot head in the indent (1 o'clock position).
Gary
PS. Welcome to the forums!
Old 02-11-2013, 05:35 PM   #5
Thanks guys, so just to make sure, it's the plate that covers the knob from the door? I think I have found a small slot buried under a lot of paint, in about the 7 o'clock position, so I just use a flat-head to pry the cover off? (I'm trying to avoid damaging the door or the handle)
Old 02-11-2013, 05:37 PM   #6
Most you push in and it releces a metal clip holding it in place.
Old 02-11-2013, 10:52 PM   #7
Thanks guys. The plate gave way after a lot of paint scraping off. The new knob is now on!
how to remove timer box for hallway lights at apartment building mikael6 Electrical 3 01-16-2013 09:31 AM
What is the best way to remove this tiling and how much to remove? wknddiy Tiling, ceramics, marble 6 12-03-2012 10:09 PM
I can't remove exterior door knob, no screws, how to remove? kata Building & Construction 3 11-01-2011 04:48 PM
How to remove outlet from tiled wall, then patch drywall and retile? Jakobud Kitchen & Bath Remodeling 18 10-15-2011 05:05 PM
Opening up a Bathroom - What can I remove? webgeek Carpentry 7 01-21-2009 12:01 PM
