Can You Mount A Storm Or Screen Door On This Front Door? - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 12-25-2012, 02:19 PM   #1
Rewards Points: 366
Can you mount a storm or screen door on this front door?
Would like to have a screen (or alternatively storm) door in front of this front door. But not sure if it's frame can support installing such a door. I only need it where the door is and not the whole door frame w/ the side windows.
I think I recall only seeing storm and screen doors on door narrower door frames that didn't have those side windows only the main door. Am I out of luck?
Can you mount a storm or screen door on this front door?-img_20120921_093023.jpg
daluu is offline   Reply With Quote
Old 12-25-2012, 04:45 PM   #2
Rewards Points: 2,238
You can mount a storm door -
For a door like you have - "Full-View", storm door -
It'll detract from the good looks of your door - less.
Measure the door - that's probably, going to be the size of the "storm" -
door.
As far as the side-lights go - those will probably, be special order.
rossfingal is offline   Reply With Quote
Old 12-25-2012, 06:06 PM   #3
Household Handyman
Rewards Points: 1,408
I did a front door/lite set such as this about a year ago. Yes you can install a storm door on this front door, but not one of the "off the shelf" items. "rossfingal" hit it again--a "Full view" door will work with this and show off most of your pretty door. You can also order, in most cases, a nice complementary trim color for this door set. And Yes, storm "windows" for the side lites can be made. I had them made for the set I did. One piece tempered glass with frame to fit. My customer had an issue with rain blowing up under the five foot (5 ft.) stoop and staining their wooden door. The finished results were very good. Do your measuring and pricing.
Old 12-25-2012, 06:29 PM   #4
Rewards Points: 6,652
Why would you want to. As for the sidelights, I would leave them alone, but as for any standard 36" Storm door, yes it would be no problem fitting it on that opening.
Old 12-25-2012, 09:45 PM   #5
Rewards Points: 366
Maybe I didn't quite phrase it right, maybe not a storm door (the glass ones?) but the tough metal screened doors (typically white or black color) or a more flimsy screen door like the sliding ones for sliding glass doors, except these swivel like a normal door rather than slide.
Wanted to be able to open front door for air/ventilation w/o pests and (bigger) dust coming through.
I saw Home Depot, Lowes has sliding screens that mount to front door frame as well, but not sure if my door frame has the space for it as the area in the center frame that's protruding out doesn't have much margin space when you account for the door knob length, it's like a half inch or less from what I recall.
Old 12-25-2012, 09:53 PM   #6
So in other words, you want your house to look like it belongs in the ghetto.
Old 12-25-2012, 09:55 PM   #7
DIY Enthusiast
sublime2's Avatar
Rewards Points: 504
Something like this?
http://www.westernmainescreendoors.com/
sublime2 is offline   Reply With Quote
Old 12-25-2012, 10:00 PM   #8
Originally Posted by sublime2 View Post
Actually more like this http://www.germes-online.com/catalog...orm_doors.html is what they are looking for. As I stated before, they want their place to appear that it belongs in the Ghetto.
As for Large particles of dust, you would not stop dust from entering a place, just by having a storm door with a screen on it.
Old 12-25-2012, 10:01 PM   #9
Rewards Points: 366
Well, I can see having a screen in front could detract from the beauty of the door. And maybe the hard metal screen doors is overkill, but is a regular mesh screen in front (swivel or retractable sliding type) not normal? Though maybe not so for a front door with the side windows, but I've seen them on the regular front doors w/o the sides.
By the way, you should see the rest of the house, and the neighborhood. The house has nice parts to it like the door, but as some of the house fixup/upgrade work was DIY (not by DIY pro) by previous homeowner(s), parts of it is crappy too. The neighborhood is ok in terms of people and condition of homes, but a little towards the ghetto-y side, you see nice houses and crappy (not well maintained) houses in the same area.
Old 12-25-2012, 10:05 PM   #10
Rewards Points: 366
Yes, gregzoll is correct for what I meant for the metal screen door.
In terms of the retractable screen doors, this is what I'm talking about:
http://www.phantomscreens.com/products/door/
and this type for the swivel version of mesh screen door:
http://www.lnt.com/product/patio-acc...reen-door.html
I don't think these are "ghetto", right? At least not the retractable type.
Old 12-25-2012, 10:22 PM   #11
The swivel are still Ghetto, the retractable is what you would see on a patio or on french doors. As for you stating the area is Ghetto or not, the term Ghetto means that the crime rate has risen, along with low income rentals have taken over.
I live in what you would say a near downtown neighborhood, with mixed living. We have low income, Section 8 on both sides of the street that I live on, but otherwise, majority of the area is safe. Only those homes that the people are either scared of being broken into, due to previous experience, or the area has allowed the gang members to take over, you only see the steel security style doors on them.
Look at what your neighbors have on their homes, along with the fact, if you do place a actual steel security door on the front of your place, how much it will detract from the value of the place, or make you a target for those looking for places that are telling them subconsciously to try to get in there, due to you are trying to protect what is inside from the outside.
If this is a covered porch, you are better to just leave the front entry as is, and utilize good locks, security system/noisy or large dog. As for fresh air from the outside, most people now days, use Air exchangers to bring in clean outside air, so that they do not have to deal with the humidity, dust, other contaminants airborne.
But if you want to go with the front entry screened door, again, go look at what others have in your area on their front doors, and how they look.
Old 12-25-2012, 10:35 PM   #12
Rewards Points: 366
What do you mean by air exchangers?
The house is old (1959) with some renovations, so it has no central AC, don't feel like using portable AC units or putting in central AC or ductless systems. Using fresh cool air outside is cheaper, and the front door is best point of entry for that area of the house.
Guess I should look into retractable unit from custom installer, will see how much that will cost.
By the way, one of my next door neighbors has a steel security door (home is rented to tenants though, not homeowner residence), but not the other. I wasn't really looking for the steel security door but the mesh screens for the front door.
Or I guess I could screen the porch instead w/ retractable screens.
Old 12-26-2012, 09:02 AM   #13
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 1,784
There are some pretty and decorative security doors out there that might not take away from the look of the home. They are going to cost a mint most times but they do exist.
Old 12-26-2012, 01:41 PM   #14
Rewards Points: 366
Just curious, can you provide any online links/references to such?
Old 12-26-2012, 02:15 PM   #15
kwikfishron's Avatar
Rewards Points: 174
I use a lot of Larson’s, check out Anderson's web site too. There are enough options to make your head spin.
The color you choose is everything in your case…anything but white.
kwikfishron is online now   Reply With Quote
Front Door inswing will hit bottom step JStephens11 Building & Construction 12 08-28-2012 11:54 PM
Need to replace front door, existing door non-standard size uncle Windows and Doors 1 07-25-2011 07:50 AM
Masonite front door hard to open and close moopey Carpentry 5 10-04-2010 11:41 PM
Storm Door Handle Installation jogan General DIY Discussions 3 06-09-2009 10:57 PM
Door -Storm Door problem bassman Building & Construction 2 01-17-2007 04:16 PM
