Can This Window Be Repaired - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 07-19-2013, 07:17 PM   #1
Rewards Points: 14
Can this window be repaired
Just discovered rain leaking through this window into the garage below. The attached picture shows the extent of the rot in the bottom rail.I have chiseled and drilled into it to remove the rotted wood.I was thinking about sealing it and then applying epoxy filler to replace it.But is this too much damage for such a repair and also what do I do about the bottom seal? This is an Andersen window;about 20 years old. Was hoping this approach might work rather than having a carpenter replace the rail.
thanks
NJPhily is offline   Reply With Quote
Old 07-19-2013, 07:32 PM   #2
Rewards Points: 13,228
Every older Anderson or Pella wood or clad window I've ever seen rots out.
Remove and replace with a replacement window and never have to deal with it again.
I use Windcor or Simonton replacements and never had a recall.
General window install questions miamicuse Windows and Doors 9 04-23-2013 09:05 PM
how to deal with a window in a shower MLMIB Kitchen & Bath Remodeling 9 09-12-2012 09:41 AM
Defog window recap greenmax General DIY Discussions 4 05-07-2010 06:00 PM
How to 'finish' outside of replacement window? KatieAK Building & Construction 9 04-02-2010 07:37 AM
Replace old window with smaller window Suncrest79 Building & Construction 3 04-15-2009 09:39 PM
