Can Someone School Me On Window Replacement? - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 09-08-2013, 07:17 PM   #1
Can someone school me on window replacement?
I have a 36" x 36" horizontal sliding vinyl window in the basement that needs replacing. The dimensions of this window are actually 36". The ones at the big box stores are actually 35.5". What gives??
jtrom is offline   Reply With Quote
Old 09-08-2013, 07:30 PM   #2
Rewards Points: 240
windows can be made pretty much any size.
what is your issue ?
Fix'n it is offline   Reply With Quote
Old 09-08-2013, 07:38 PM   #3
I guess I need to know the difference between new construction and replacement windows.....
Old 09-08-2013, 08:19 PM   #4
Rewards Points: 240
new construction windows have a flange around them. this nailing flange fastens the window to the structure.
http://www.google.com/search?q=windo...w=1066&bih=598
replacement windows do not have this flange. they slid into a hole. and are screwed down (this is a very basic definition). this window replacement method is much less disturbing to the structure.
Old 09-09-2013, 10:27 AM   #5
Roofmaster
Rewards Points: 2,210
That gives you 1/4 inch all around to shim plumb and level. A lot of RO's are not. Use shim, check for plumb level and square, through and pilot drill, and use stainless steel screws. Use foam backerod on the outside, and inject and tool color matched high quality silicone sealant around the window. You should install a drip cap and sill pan depending on the application. I would use a casement window if you can. Much tighter.
The Following User Says Thank You to jagans For This Useful Post:
Windows on Wash (09-16-2013)
how to secure replacement casement window tambo Windows and Doors 5 08-10-2012 11:49 AM
Old replacement window jsfoltz Windows and Doors 1 08-26-2011 07:27 PM
Window Replacement mark2741 Remodeling 5 07-21-2010 03:33 PM
How to 'finish' outside of replacement window? KatieAK Building & Construction 9 04-02-2010 06:37 AM
How to install Replacement window in 2x4 frame? BFD8 Remodeling 18 01-07-2009 11:56 AM
