-   Windows and Doors (http://www.diychatroom.com/f104/)
-   -   Can someone school me on window replacement? (http://www.diychatroom.com/f104/can-someone-school-me-window-replacement-186695/)
jtrom 09-08-2013 07:17 PM
I have a 36" x 36" horizontal sliding vinyl window in the basement that needs replacing. The dimensions of this window are actually 36". The ones at the big box stores are actually 35.5". What gives??
Fix'n it 09-08-2013 07:30 PM
windows can be made pretty much any size.
what is your issue ?
jtrom 09-08-2013 07:38 PM
I guess I need to know the difference between new construction and replacement windows.....
Fix'n it 09-08-2013 08:19 PM
new construction windows have a flange around them. this nailing flange fastens the window to the structure.
http://www.google.com/search?q=windo...w=1066&bih=598
replacement windows do not have this flange. they slid into a hole. and are screwed down (this is a very basic definition). this window replacement method is much less disturbing to the structure.
jagans 09-09-2013 10:27 AM
That gives you 1/4 inch all around to shim plumb and level. A lot of RO's are not. Use shim, check for plumb level and square, through and pilot drill, and use stainless steel screws. Use foam backerod on the outside, and inject and tool color matched high quality silicone sealant around the window. You should install a drip cap and sill pan depending on the application. I would use a casement window if you can. Much tighter.
