Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Windows and Doors
Old 11-24-2012, 09:55 PM   #1
Can some form of a door be installed without using the ceiling?
Hey everyone, I am a completely new to this so I am sorry if my question sounds misinformed. Basically, I rent a basement room with a 63 inch width by 72 inch length entrance way. The problem is the drop ceiling foam panels run throughout the basement, and I cant change that. I understand logically I cant have a real door because it cant touch the panel, but is there a solution? I would appreciate any and all help that comes my way. Thank you.
diydummy86 is offline   Reply With Quote
Old 11-24-2012, 10:27 PM   #2
funfool's Avatar
Welcome to diy
Maybe re read your post, Not sure I saw a question to offer a solution.
No worries, just ask and will be many here to help.
If it was easy, we would not call it work!
funfool is online now   Reply With Quote
Old 11-24-2012, 10:44 PM   #3
My question is, is there a way to mount a door or doors for a 63 W by 79 L space without having it mounted by the ceiling? The ceiling to the entrance way is a drop ceiling with foam paneling. But i desperately need some sort of privacy. Room dividers do not seem ideal.
Old 11-24-2012, 11:08 PM   #4
some pictures might help to find a solution.
redman88 is offline   Reply With Quote
Old 11-25-2012, 12:31 AM   #5
you should be able to buy solid slab doors and cut them down to fit the opening. the jamb would have to be remade also.
Old 11-25-2012, 10:14 AM   #6
Originally Posted by diydummy86 View Post
63 W by 79 L space
63" wide by 79" tall ? opening for door/s
DIY'er, out of necessity. if i did this for a living, i would make about $3.50 an hour
i didn't make this world. i just live in it.
be careful of whom you make fun of. one day, that could be you...
Fix'n it is online now   Reply With Quote
Old 11-25-2012, 12:48 PM   #7
What part of the door would attach to the ceiling? Unless it's a bifold or slider?
msaeger is offline   Reply With Quote
Old 11-25-2012, 12:58 PM   #8
memarybe's Avatar
Why not use a telescoping shower rod ? Then you can hang some sort of curtain from it . At least you could gain some privacy until you come up with a more permanent solution.
memarybe is offline   Reply With Quote
Old 11-25-2012, 01:03 PM   #9
sdsester's Avatar
If your landlord will allow it, you can mount barn door hardware to the walls (you will want to make sure you anchor into the studs) for rolling doors that would look nice, be easy to install, not too expensive and provide the privacy you need. For example:
sdsester is offline   Reply With Quote
Ceiling issues in old home tbarker13 Drywall & Plaster 5 01-22-2012 09:53 PM
Creating a vaulted ceiling for patio tcaesar1 Building & Construction 1 04-26-2011 11:30 PM
Level 5 finish expectations? Cracked ceiling.....input needed please! HeatherJ Drywall & Plaster 6 01-14-2011 06:04 PM
Drywall ceiling: Water Damage, looking for advice dawho1 Building & Construction 11 09-13-2010 11:05 AM
Advice for installing ceiling fan Ceiling Fan Man Electrical 5 06-02-2009 05:18 PM
