-   Windows and Doors (http://www.diychatroom.com/f104/)
-   -   Can some form of a door be installed without using the ceiling? (http://www.diychatroom.com/f104/can-some-form-door-installed-without-using-ceiling-164586/)
diydummy86 11-24-2012 08:55 PM
Hey everyone, I am a completely new to this so I am sorry if my question sounds misinformed. Basically, I rent a basement room with a 63 inch width by 72 inch length entrance way. The problem is the drop ceiling foam panels run throughout the basement, and I cant change that. I understand logically I cant have a real door because it cant touch the panel, but is there a solution? I would appreciate any and all help that comes my way. Thank you.
funfool 11-24-2012 09:27 PM
Welcome to diy
Maybe re read your post, Not sure I saw a question to offer a solution.
No worries, just ask and will be many here to help.
diydummy86 11-24-2012 09:44 PM
sorry
My question is, is there a way to mount a door or doors for a 63 W by 79 L space without having it mounted by the ceiling? The ceiling to the entrance way is a drop ceiling with foam paneling. But i desperately need some sort of privacy. Room dividers do not seem ideal.
redman88 11-24-2012 10:08 PM
some pictures might help to find a solution.
DannyT 11-24-2012 11:31 PM
you should be able to buy solid slab doors and cut them down to fit the opening. the jamb would have to be remade also.
Fix'n it 11-25-2012 09:14 AM
Originally Posted by diydummy86 (Post 1059680)
63 W by 79 L space
63" wide by 79" tall ? opening for door/s
msaeger 11-25-2012 11:48 AM
What part of the door would attach to the ceiling? Unless it's a bifold or slider?
memarybe 11-25-2012 11:58 AM
Why not use a telescoping shower rod ? Then you can hang some sort of curtain from it . At least you could gain some privacy until you come up with a more permanent solution.
user1007 11-25-2012 12:03 PM
If your landlord will allow it, you can mount barn door hardware to the walls (you will want to make sure you anchor into the studs) for rolling doors that would look nice, be easy to install, not too expensive and provide the privacy you need. For example:
https://encrypted-tbn0.gstatic.com/i...foVFKlSQj5O_Xw
https://encrypted-tbn3.gstatic.com/i...F7moOnnYkJXhgg
https://encrypted-tbn1.gstatic.com/i...bXXRlhyn-dIpNw
