Can I Just Replace The Glass ??? - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 03-10-2014, 11:41 PM   #1
Can I just replace the glass ???
I need to replace a double pane fake divided light window (40 x 73 in) which I suspect I cracked by not including some cushion between the glass and the sill I repaired with epoxy putty 6 months before. I have only had one estimate by a guy who said he could replace/ custom rebuild the window for $3K. He said he couldn't replace the glass. He furthermore couldn't promise the glass would match the other windows on the front of my house.
1) Is that true? Is there no way to remove the casement ( I would probably have to saw out the epoxy) and install a new IGU with some sort of gasket, and screw and glue the casement back together?
I don't really want to do it myself, and I recognize it needs a professionals touch; but it seems like an interested carpenter could do the work for a lot less.
Admittedly, it was a low quality builders window to start with which I suspect was why the sills rotted out to start with.
Thanks for any advice.
David- Dallas
Can I just replace the glass ???-small-window.jpg   Can I just replace the glass ???-sill-small.jpg
davidwat is offline   Reply With Quote
Old 03-11-2014, 06:11 AM   #2
JOATMON
ddawg16's Avatar
Rewards Points: 1,454
For that price you could put in 3 new windows that are low E, double pane, tempered....
If your already having rot issues.....I would look at a total replacement....of all 3.
Look into fiberglass/vinyl. Mine are fiberglass on the outside....vinyl on the inside....In my area, I bet each window would be about $600 ea...of course I'm the kind of guy that would do the install myself....but I bet you could get it done for about $200/window.
Where are you located?
ddawg16 is online now   Reply With Quote
Old 03-11-2014, 09:07 AM   #3
Thanks for your interest.
I'm in Dallas near SMU. It turns out that estimate didn't even include installation - only custom construction of the window to match. Matching is a major concern which makes a new window a less appealing option.
David - Dallas
Old 03-11-2014, 09:10 AM   #4
It may require some +/- skilled carpentry which may be the stumbling block to the project. Glass people don't know carpentry and carpenters don't know glass?
David - Dallas
Old 03-11-2014, 09:15 AM   #5
JOATMON
ddawg16's Avatar
David....have a look at the link in my signature....ALL of the windows in my addition are custom....nothing was a standard size.
In your case....replacing all 3 could have several advantages....
When we replaced the existing windows with new ones....besides the thermal improvements....we were amazed at how much sound they blocked. Big difference in sound. Making a window tempered...added maybe $50 to the cost.
For my house and addition....15 windows (some of them large casements) $7000
The Following User Says Thank You to ddawg16 For This Useful Post:
davidwat (03-11-2014)
Old 03-11-2014, 10:14 AM   #6
Thanks, Ddawg.
Was that a change from single to double pane or from double pane to triple pane? For some reason, I can't see your link. Also, I need wood casements to match the rest of the front windows.
Old 03-11-2014, 11:21 AM   #7
JOATMON
ddawg16's Avatar
Originally Posted by davidwat View Post
Thanks, Ddawg.
Here it is....It's in my signature
2-Story Addition...Trials and Tribulations
Old 03-11-2014, 12:54 PM   #8
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 3,120
At that price, yank them out and replace them.
Old 03-13-2014, 01:09 PM   #9
Turns out the window is a 20 year old Caradco sash mounted picture window, and I may be able to get Jeld-Wen to duplicate the sash - preferably with a newer more secure glass/window connection. That should make it a lot cheaper to replace.
David - Dallas
Old 03-13-2014, 03:06 PM   #10
Originally Posted by Windows on Wash View Post
+1
The problem is matching replacements to the rest of the front of the house. Of course, considering the problems I have had, I may need to replace them all anyway.
David - Dallas
caulking old wood windows andyman Windows and Doors 10 12-31-2011 03:39 PM
How Do I Replace This Glass? linuxrunner Windows and Doors 8 11-11-2011 02:47 PM
Pella sliding glass door trim seperated from glass Scuba_Dave Building & Construction 6 03-10-2011 12:28 PM
Replace Glass In Metal Frame??? amarlls General DIY Discussions 4 07-16-2008 04:46 PM
Sweating windows big daddy-o General DIY Discussions 15 01-06-2008 02:41 PM
