Can I Cut 2" Off Of Bottom Of Interior Wood Door - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 02-16-2013, 10:32 PM   #1
Rewards Points: 30
Can I Cut 2" Off of Bottom of Interior Wood Door
Hi
I am replacing some old hollow doors with solid wood pre-hung doors (Reliabilt from Lowes). My current doors are 78" in length and the stock doors are all 80". The door packaging indicates the maximum amount that can be trimmed from the bottom is 1".
Can I trim 2"? Does the extra 1" compromise the integrity of the door or the frame which would obviously need to be trimmed as well.
I haven't found anything on the web indicating otherwise?
BenLehman is offline   Reply With Quote
Old 02-16-2013, 10:34 PM   #2
Framing Contractor
Rewards Points: 112
You can cut more. Any more than 1 inch will mean you will have to insert a filler afterwards.
sixeightten is online now   Reply With Quote
Old 02-16-2013, 10:44 PM   #3
Rewards Points: 30
Thanks for the quick reply.
Filler for a solid door? I get the filler on the hollow core doors.
Old 02-16-2013, 10:50 PM   #4
Plumber
TheEplumber's Avatar
Rewards Points: 452
I bet your solid core is actually particle/press wood core under a veneer. Cutting more then an inch means you're removing the solid wood frame and exposing the inner core
Old 02-16-2013, 11:25 PM   #5
Rewards Points: 13,274
Reframe the door opening so a standard door will work of buy a better quality door that's solid wood.
Ever had to make a slab door work. Boy are you in for a treat.
Old 02-17-2013, 08:32 AM   #6
Rewards Points: 194
I've cut hollow core doors and been able to knockout and glue back in the filler portion from what I cut.
Larryh86GT is offline   Reply With Quote
Old 02-17-2013, 09:16 AM   #7
Rewards Points: 700
Since this is going to be a labor intensive custom fit DIY job, does the package give any reason on inch couldn't be cut from each end?
Old 02-17-2013, 10:09 AM   #8
Rewards Points: 89
Lowes sells a 78 inch solid wood door,why are you screwing with an 80 inch door,bring it back an have them order the right size for you
spring3100 is offline   Reply With Quote
Old 02-17-2013, 10:13 AM   #9
Rewards Points: 30
Thanks for everybody's replies.
However, the door is not a hollow core door, it is a 6 panel solid pine wood door. Also, it is a pre-hung door, not a slab. As far as the directions, I'm not sure why they indicate to limit the amount to be trimmed to 1". Even if I tried to special order a door, it would still be a 80" door. If I can cut the door down to 78", it won't be labor intensive to install. Just wanted to know why they indicate a max of 1".
Ben
Old 02-17-2013, 04:08 PM   #10
Rewards Points: 89
Ben
Both Home Depot and Lowes sell 78 inch solid or hollow core doors,not sure why you couldn't use them,cutting down an 80 inch prehung is going to look exactly like that,a cut down door,good luck anyways
Old 02-17-2013, 06:21 PM   #11
There are 3 different products being discussed here -- 1. STILE and RAIL Pine Door 2. hollow core door 3. Solid core door (which is a hollow core door with alot more filler. You can cut the 2 inches off the Pine door but it will void the warranty (No big deal) however the reason they state one inch is because you could be cutting into the Biscuits that are gluing the RAILS to the STILES. So I say -- Grab a circular saw and a straight edge and have at it.
ramjet_40 is offline   Reply With Quote
Old 04-14-2013, 03:05 PM   #12
Rewards Points: 81
the package wont tell you not to cut from each end but it also wont tell you not to install it upside down. You just cant do it.
one cut is offline   Reply With Quote
Old 04-14-2013, 04:02 PM   #13
funfool's Avatar
Rewards Points: 534
<b>I am replacing some old hollow doors with solid wood pre-hung doors<b/>
If these are pre hung, if you cut the top, will also have to relocate the hinges.
If is not a pre hung and you need to mortice the hinges and drill for the hardware, you can cut it where you want.
funfool is offline   Reply With Quote
Tags
cut , door , interior , trim , wood
Front Door inswing will hit bottom step JStephens11 Building & Construction 12 08-28-2012 11:54 PM
Patio door bottom sill over brick/concrete block cjf1980 Building & Construction 18 04-12-2012 10:56 AM
Pre-Hung doors - How to Hang Willie T How To Guides 23 01-28-2011 10:24 AM
Door bottom (sweep) operagost General DIY Discussions 6 12-06-2010 11:26 AM
Larson Storm Door Won't Close Snowbird Building & Construction 13 03-03-2009 04:01 AM
