Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Windows and Doors
Old 08-29-2011, 07:13 PM   #1
Broken Octagonal Window
I have a Hurd octagonal window with the inside pane cracked. I need to know how to remove the window so I can replace the glass.
buckbeaver is offline   Reply With Quote
Old 08-29-2011, 07:23 PM   #2
Super Moderator
Is it a working window (opening) or fixed (non-opening)?
Old 08-29-2011, 07:55 PM   #3
Fixed.
Old 08-29-2011, 08:24 PM   #4
Super Moderator
Is there a removable trim on the inside that would allow the glass to be removed?
You sound intelligent so my guess is no----
Installing a Replacement Vinyl window with brick mold jlatulippe Carpentry 4 06-23-2011 03:05 PM
How to fix a broken frame corner of a slide window George II Windows and Doors 1 05-07-2011 03:04 PM
Defog window recap greenmax General Discussion 4 05-07-2010 06:00 PM
help need to know how to replace windows wrapped in drywall caide3 Carpentry 4 03-02-2010 01:41 PM
Problem with window and everything around it malfunction Building & Construction 3 05-26-2009 06:11 PM
