Brand New Replacement Windows Leak Cold Air! - Windows and Doors - Page 2 - DIY Chatroom Home Improvement Forum
Old 01-08-2013, 09:27 AM   #16
Rewards Points: 2,516
Originally Posted by saturn500f View Post
Here are a bunch of photos so you can really see what is going on, I posted them on a website to save space here:
Views of the windows
Do your windows have a sort of compression tracking along each sode that the sashes ride up and down in. I have Hurd windows and these are called "side balances"
I had one window that would never fully seal. I had the drywall removed for an inrelated reason around that window and sure enough the rough framing was not square. I will try and find photos of that.
Below are 2 photos showing the side balances. Is this similar to yours??
Brand new replacement windows leak cold air!-100_4376.jpg   Brand new replacement windows leak cold air!-100_4403.jpg
hammerlane is offline   Reply With Quote
Old 01-08-2013, 09:48 AM   #17
Here were the photos of my problem window. when I had the drywall off, I was able to shim between the jack stud and the window to close that gap.
Old 01-08-2013, 10:30 AM   #18
Home Performance
HomeSealed's Avatar
Rewards Points: 712
Please take no offense hammerlane, but to alleviate any confusion for the OP I just want to point out that the rba window that he/she has does not have the compression jambliners/balance system as shown in your pics, nor will his issue be fixed by simple shimming. The window will likely need to be reset to fix those reveals and make the unit square as designed. Even if shimming was a solution, this is an insert installation, so it would be between the original buck frame and the master frame of the new unit. Nowhere near the jack studs or anywhere else in the RO.
Replacement Windows, doors, siding, roofing, insulation, and BPI certified energy consulting, Building Analyst 5051322
www.HomeSealed.com
Replacement Windows Milwaukee
HomeSealed is offline   Reply With Quote
Old 01-08-2013, 12:11 PM   #19
No offense taken. I agree with what you quoted.
Old 01-08-2013, 11:05 PM   #20
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 5,182
Wowsers.
Bad set job and capping to boot.
As HomeSealed said previously, RBAs tend to run pretty good shops. Andersen doesn't set up any clown. That being the case, they should make this right and get you fixed up.
I would be willing to bet that you call them with this and you will get a call back straight away.
Old 02-01-2013, 11:16 PM   #21
Anything?
What luck have you had? I know this is technically the franchisee's responsibility to make it right-but Andersen is not happy when they hear about unhappy homeowners, so just wondering if the issue has been fixed yet.
Windasman is offline   Reply With Quote
Installing replacement windows over drywall? lafern Windows and Doors 7 06-13-2012 01:17 PM
Andersen vs Jeld Wend Replacement Windows ... JasonCA Remodeling 13 03-20-2012 10:46 PM
Vinyl replacement windows. joefromcal Building & Construction 8 02-20-2011 09:54 PM
Replacement Windows Smaller Than Rough Opening stubits Remodeling 1 08-25-2010 06:19 AM
Very Small leak at Shower Valve on Cold Water Side, Threaded. Tighten it more or ? twilightcall Plumbing 3 08-25-2008 08:19 AM
