Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Windows and Doors
Old 10-20-2012, 11:34 AM   #16
AHH, SPANS!!!
Bottom of sidelights rusting, leaking into home
It is coming in where the bottom of the sidelight meets the horizontal brown weather strip door bottom. you could try clearing as much rust as you can and caulking with a heavy duty clear caulk along the top of the brown door bottom and up onto the door some.
hand drive is offline   Reply With Quote
Old 10-20-2012, 02:43 PM   #17
concretemasonry's Avatar
Poorly flashed and installed door and poor or no no proper flashing for the 3'-4' canopy over the door. Very common with builders that just use a carpenter to install a door. Many better builders hire a certified window/door subcontractor (mainly for insurance and liability problems from mold and moisture damage in the wall).
Dick
concretemasonry is offline   Reply With Quote
Tags
leaking, rust, sidelight
Need URGENT help with question regarding fixing electrical panel in home asledge Electrical 66 02-22-2013 05:49 PM
How to I legally pursue this home inspector? wzolla86 General Discussion 28 05-15-2012 03:21 AM
Attaching 2" Schedule PVC conduit to the bottom of a mobile home rrolleston Electrical 2 01-25-2012 08:54 PM
Home built in 1860 - leaking basement b/c of a compromised foundation LBS Building & Construction 2 11-04-2011 12:59 PM
A facelift for your home Grumpy Remodeling 0 07-07-2004 08:43 PM
