Bottom Reveal Is Not The Same Height Across - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 08-06-2012, 12:21 PM   #1
bottom reveal is not the same height across
After installing a prehung door the bottom reveal is not the same height across the bottom. Had to adjust the top hindge to make the the top of the door level. The frame is square and the door is square in the frame. How do I adjust the bottom reveal?
shirj is offline   Reply With Quote
Old 08-06-2012, 12:32 PM   #2
hanging a door
I have installed 100's of doors over the years.
First thing is you need a level/say a 2 footer.To make the level longer just hold it against a straight piece of lumber.
Now check the floor for level.Set the leg of the jamb tight to the high point of the floor.attach this jamb to the framing/make sure it is plumb.Now lift the free jamb until the head reveal is the same.shim and attach jam.
finally determine the gap needed at the base of door/cut even with slope of floor.
hope this helps,
Marbledust is offline   Reply With Quote
Bottom Plate for Stud Wall svaic00 Building & Construction 3 07-10-2012 02:07 PM
LevelQuik to raise basement bathroom floor height jonhayden Flooring 8 06-29-2012 08:55 AM
2 yr. pool liner has wrinkle on bottom HELP Tric Introductions 0 09-10-2010 12:13 PM
How to frame new floor to match existing floor height taylor01 Carpentry 4 04-04-2010 08:59 PM
Height of Fence = Height of Posts Necessary Dallas Building & Construction 2 11-05-2007 09:47 AM
