Black Goo Weather Strip? - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 05-10-2011, 11:41 AM   #1
Hi All,
Putting up a new front door; old weather strip is accompanied by a hard black substance that looks like it may have once been soft but has long since hardened. I'm a little hesitant to chip it away as it looks a bit like a black mastic adhesive and the house was built in the mid 1950s . However, I've only know black mastic to be on flooring and there is no sign of it anywhere else in the house; any ideas as to what this stuff might be?
Jgore is offline   Reply With Quote
Old 06-08-2011, 12:11 PM   #2
jason.r's Avatar
It sounds like you have it right. Older weather stripping like this is horrible. As soon as you chip it off I would do an assessment on what type of jamb you are dealing with, if it is kerfed - has a notch in it I would replace it with a push in type strip.
If not, use a weather strip with an adhesive backing, but never go back to that "goo" that is in there now.
Even though some of the wood is rotten I would still recommend replacing the strip as energy bills are high no matter where you are in the country!
jason.r is offline   Reply With Quote
Please Help! 3 way switches controling 2 light fxtures. HelloMotto Electrical 52 11-05-2014 04:28 PM
Double switch wiring rockclimber Electrical 18 03-18-2012 10:13 PM
Help with Two Switches & Two Lights simplyphp Electrical 36 11-25-2010 02:47 PM
Black Iron Exposed? jamiedolan Plumbing 0 08-14-2009 10:16 AM
Double Glazed Windows Black Sealing Strip hansi General DIY Discussions 2 09-08-2005 04:05 AM
