Best Window Sealant - Windows and Doors - Page 2 - DIY Chatroom Home Improvement Forum
Old 02-02-2012, 02:33 AM   #16
Rewards Points: 1,062
Originally Posted by kwikfishron View Post
Donít forget a good caulking gun. The $4 gun wonít do it.
recommendations?
Old 02-02-2012, 06:21 AM   #17
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 894
Originally Posted by amakarevic View Post
recommendations?
The premium guns at Big Blue/Orange aren't bad either. The stamped steel cheapos are crapola though and will not give you good modulation of the caulk disbursement.
Old 02-02-2012, 08:02 AM   #18
kwikfishron's Avatar
Rewards Points: 90
recommendations?
These are the ones Iíve been using for the last couple of years. Iím sure there are better guns out there but this is the best my lumberyard has to offer and works just fine.
http://www.google.com/products/catal...ed=0CH8Q8gIwAA
kwikfishron is online now   Reply With Quote
Old 02-02-2012, 01:25 PM   #19
Home Performance
HomeSealed's Avatar
Rewards Points: 710
I agree with both comments above. You can find something good enough for $15-$20. The key is learning how it works, as in how much pressure to use, and how much extra material will come out between pumps so that you can control your speed without leaving lumps.
Replacement Windows, doors, siding, roofing, insulation, and BPI certified energy consulting, Building Analyst 5051322
www.HomeSealed.com
Replacement Windows Milwaukee
HomeSealed is offline   Reply With Quote
Old 02-03-2012, 06:10 PM   #20
i think that's what i got. it is black in color and was around $10. it was advertised as more advanced than the $3 orange ones. previously, i had invested in a $15 Raptor that i got at Ferguson plumbing supply store but that proved to be a total POS
Old 02-03-2012, 07:10 PM   #21
Home Performance
HomeSealed's Avatar
Rewards Points: 710
How could it be that bad with a name like RAPTOR !?
... You should be set with the orange and black one at HD. I have a couple of those.
www.HomeSealed.com
The Following User Says Thank You to HomeSealed For This Useful Post:
amakarevic (02-03-2012)
Old 02-03-2012, 09:33 PM   #22
Rewards Points: 90
Gun aside, if you’re using Quad (or any other poly caulk) be sure to have a rag and some paint thinner by your side.
That stuff sticks to everything whether you want it or not.
If you get it on your clothes, it’s there for life.
Get it in your hair…..you’ll have to cut it out.
The good news is... it will wear off your skin in 2 or 3 days if you pick at it enough.
The Following User Says Thank You to kwikfishron For This Useful Post:
Old 02-04-2012, 10:21 AM   #23
Rewards Points: 894
Gun aside, if youíre using Quad (or any other poly caulk) be sure to have a rag and some paint thinner by your side.
If you get it on your clothes, itís there for life.
Get it in your hairÖ..youíll have to cut it out.
That is why I hate that stuff.
Make you look like you work in a marshmallow factory and forgot to wash your hands.
Old 02-05-2012, 06:41 PM   #24
unrelated to this particular application, do you guys have any idea how Quad bonds to plastic and whether it could be used to patch small gaps watertight?
thanks
Old 02-05-2012, 10:12 PM   #25
Home Performance
HomeSealed's Avatar
Rewards Points: 710
It bonds fabulously to plastic... On patching small gaps, that depends...
www.HomeSealed.com
Old 02-05-2012, 10:19 PM   #26
Question
well, i'm into whitewater kayaking and, occasionaly, boats break on impact with rocks and then most people plastic weld them, which is a colossal P.I.A. recently, there is a product called GFlex epoxy, which works like a fiberglass cloth patch with epoxy and hardener, which makes it easier, even on plastic boats (this was an innovation cause such patching was only possible on fiberglass boats before). now, i was thinking, if this Quad stuff is as strudy as you're saying, can it be used to fix gashes maybe up to an inch wide and a few inches long if you put something on the other side of the hull to stop it from dripping through, i.e. hold it in place as a mould until it hardens.
what do you think
Old 02-06-2012, 06:36 AM   #27
Rewards Points: 894
I feel like this is an ad for Mighty Putty.
The Following User Says Thank You to Windows on Wash For This Useful Post:
HomeSealed (02-06-2012)
Old 02-06-2012, 09:35 AM   #28
Home Performance
HomeSealed's Avatar
Rewards Points: 710
I would use it for that purpose at your own risk. I like it, but that is probably asking a bit too much. The mighty putty might be better.
www.HomeSealed.com
Old 02-06-2012, 03:39 PM   #29
no, the putty won't do
Old 02-07-2012, 08:56 AM   #30
Rewards Points: 894
Best thing to do for fixing plastic in that situation is to weld it.
You can buy a plastic welder for cheap and donor plastic of the same material can be your filler.
Tags
sealant , window , window flashing
Exterior window sealant johnnyk42 Windows and Doors 4 01-04-2012 12:25 PM
Best sealant for window frame darsunt Building & Construction 11 10-20-2011 10:02 AM
Defog window recap greenmax General DIY Discussions 4 05-07-2010 06:00 PM
help need to know how to replace windows wrapped in drywall caide3 Carpentry 4 03-02-2010 01:41 PM
Problem with window and everything around it malfunction Building & Construction 3 05-26-2009 06:11 PM
