Best Window Sealant - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 01-31-2012, 12:14 PM   #1
Rewards Points: 1,062
Question
best window sealant
what is the best caulking to use to seal a window? i got some Sika Construction Sealant from HD as I've been real please with their other products (particularly Anchoring Epoxy, that thing rocks my world) but was wondering if there is anything better.
my window goes directly against masonry on 3 sides and a wooden bulkhead + aluminum flashing on the 4th side. in case that matters.
thanks
Old 01-31-2012, 12:47 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 5,554
Quad, although I don't care for the smell of it, is pretty well regarded.
What color does it need to be?
The Following User Says Thank You to Windows on Wash For This Useful Post:
amakarevic (01-31-2012)
Old 01-31-2012, 03:09 PM   #3
Home Performance
HomeSealed's Avatar
Rewards Points: 712
+1 on the Quad... If you think it smells bad now, what did you think of the old formula!?... That stuff was pretty harsh.
Replacement Windows, doors, siding, roofing, insulation, and BPI certified energy consulting, Building Analyst 5051322
www.HomeSealed.com
Replacement Windows Milwaukee
HomeSealed is offline   Reply With Quote
The Following User Says Thank You to HomeSealed For This Useful Post:
Old 01-31-2012, 08:08 PM   #4
got Quad. thanks
Old 02-01-2012, 07:30 AM   #5
My guys caulked a sample inside my office one time and it nearly knocked me on my keyster when I walked in.
Old 02-01-2012, 07:37 AM   #6
Rewards Points: 14,306
If your thinking about using Quad around that aluminum coil stock to brick area, think again, It will be a gooy imposable to get off mess.
I'd use Alex 230 and lots of water and a soaking wet sponge to wipe it down for at least this area.
Old 02-01-2012, 08:21 AM   #7
MJW
I agree. quad makes a mess on brick and stone, and very hard to remove. Do the next guy a favor and use some silicone.
MJW is offline   Reply With Quote
Old 02-01-2012, 11:16 AM   #8
Home Performance
HomeSealed's Avatar
Rewards Points: 712
We use quad on every brick and stone install that we do. Comes out beautifully, it just takes some skill. I will say though that if you use quad, plan on laying a nice bead because it definitely is not the easiest caulk to tool. That typically does result in a mess. If you are a poor caulker and will need to tool it, then follow Joe's advice.
www.HomeSealed.com
Old 02-01-2012, 03:34 PM   #9
Question
i don't get it: i have some masonry and some aluminum stock coil contact. which one is good for which?
thanks
Old 02-01-2012, 03:44 PM   #10
Home Performance
HomeSealed's Avatar
Rewards Points: 712
My comments above (as well as everyone else's) were pertaining to your circumstance of aluminum to brick.
Myself and WoW prefer Quad, MJW likes silicone (which is not the worst choice, imo), and Joe's suggestion was to use a caulk that is more "tool-able", which is a valid suggestion if you are not skilled with a caulk gun.
www.HomeSealed.com
Old 02-01-2012, 03:55 PM   #11
Home Performance
HomeSealed's Avatar
Rewards Points: 712
Here is a pic of quad from aluminum to brick. No tooling necessary, no mess, just beauty.
www.HomeSealed.com
Old 02-01-2012, 04:14 PM   #12
Question
what does it take to be "skilled with a caulk gun", ferchrissake?
Old 02-01-2012, 04:28 PM   #13
MJW
It does take some skill and some time to get good at. That's why quad works so well. It is consistent and comes out well if it's not too old or cold. It's just a pain to take off of brick when you have to redo it.
I like quad for what it is, just prefer silicone when it comes to removing it.
It's worth paying for good caulking.
Believe it or not, but there are Union window guys that all they do is caulking.....and they can lay one heck of a bead.
The Following 2 Users Say Thank You to MJW For This Useful Post:
HomeSealed (02-01-2012), Windows on Wash (02-02-2012)
Old 02-01-2012, 05:15 PM   #14
Home Performance
HomeSealed's Avatar
Rewards Points: 712
Practice and technique. Sounds silly, but it really is an art form.
I have had crews in the past that could do excellent work all the way around, but they couldn't caulk to save their lives so they had to go. Guess what the first thing people look at on the outside of a window install?
www.HomeSealed.com
Old 02-01-2012, 08:27 PM   #15
kwikfishron's Avatar
Rewards Points: 998
Isn't that the truth.
Don’t forget a good caulking gun. The $4 gun won’t do it.
The guns I use cost sixteen bucks. I miss the orange ones that cost $7 that were “Made in England”. I can’t find them anymore.
kwikfishron is online now   Reply With Quote
Tags
sealant , window , window flashing
Exterior window sealant johnnyk42 Windows and Doors 4 01-04-2012 11:25 AM
Best sealant for window frame darsunt Building & Construction 11 10-20-2011 09:02 AM
Defog window recap greenmax General DIY Discussions 4 05-07-2010 05:00 PM
help need to know how to replace windows wrapped in drywall caide3 Carpentry 4 03-02-2010 12:41 PM
Problem with window and everything around it malfunction Building & Construction 3 05-26-2009 05:11 PM
