Best Way To Accurately Measure Window Opening - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 07-21-2011, 12:20 PM   #1
Best way to accurately measure window opening
Hello friends,
I want to replace the windows on my 60's built ranch home. I want to go stud-to-stud (not interested in replacement windows).
The question: What is the most accurate method of measuring the window opening?
Thanks!
Nick
CallMeNick is offline   Reply With Quote
Old 07-21-2011, 02:43 PM   #2
Rewards Points: 20
Since you need to do it sooner or later anyway, I would pop the interior trim.
Old 07-21-2011, 03:24 PM   #3
Hi DexterII<
Thanks for the quick reply.
Ok, so pop the trim then mean from the exposed studs, I assume.
Old 07-21-2011, 03:26 PM   #4
lol I mean
...measure from the exposed studs
Old 07-21-2011, 04:15 PM   #5
Rewards Points: 20
If you are simply budgeting for this, I would suggest guestimating the size, and you should be able to get close enough for the dollars and cents to come out close, but if you are going ahead with it, and don't want to reframe anything, yes, this is what I would do. Stay tuned though, because there are a lot of smart people here, and someone may offer some better advice.
Old 07-21-2011, 06:20 PM   #6
kwikfishron's Avatar
Rewards Points: 84
What type of windows do you have now, aluminum? Posting a picture inside and out would help.
kwikfishron is offline   Reply With Quote
Condensation on fiberglass window frame creamaster General DIY Discussions 11 01-05-2012 08:42 PM
Tight fitting vinyl replacement windows Pittsville Building & Construction 24 10-11-2011 11:19 AM
Window Pane Replacement rjschwar Building & Construction 3 08-27-2010 08:15 AM
help need to know how to replace windows wrapped in drywall caide3 Carpentry 4 03-02-2010 01:41 PM
Problem with window and everything around it malfunction Building & Construction 3 05-26-2009 06:11 PM
