The Best Replacment Window - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 09-24-2012, 08:23 PM   #1
The best replacment window
Are simonton 5500 series windows a good quality replacment window.
eastlakeclay is offline   Reply With Quote
Old 09-24-2012, 08:36 PM   #2
Rewards Points: 13,712
I like um. Even installed them in my own home I liked them so much.
Never once had a call back for fogged up glass on any I've installed.
Old 09-24-2012, 09:22 PM   #3
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 4,608
Well built and supported window.
Old 09-25-2012, 10:48 AM   #4
Home Performance
HomeSealed's Avatar
Rewards Points: 712
Good window, good company. Since you have it listed in your title, I would just add that no, they are not the best if you are basing that purely on the performance and quality of the product, but I'd say that they are a solid "B" in that regard. The thermal and structural ratings are not quite on par with some of the very top vinyl choices, nor is the fit and finish IMO, however they get an "A" rating for company support by every account that I have seen/experienced. Overall, I think that you'd be satisfied with the choice, and it is certainly one of the better options that is widely available for DIY. I would put the Plygem Premium (Great Lakes) in that same category.
Replacement Windows, doors, siding, roofing, insulation, and BPI certified energy consulting, Building Analyst 5051322
www.HomeSealed.com
Replacement Windows Milwaukee
HomeSealed is offline   Reply With Quote
Old 09-25-2012, 04:59 PM   #5
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,200
personally never heard of them, there is a large number of window and door companies out there. some are national and some are local. the small companies sometimes have higher quality control where they aren't cranking out large numbers of product..
the big companies usually have different lines of their product. low end, mid range and high end. lower end is typically where issues occur as they get cranked out of hte factory hand over first.
i mostly use peter kohler windows, occasionally Anderson windows along with Pella or Marvin
woodworkbykirk is offline   Reply With Quote
Old 09-26-2012, 06:50 AM   #6
Kirk,
From that list, you can definitely tell you deal in wood.
Simonton is a vinyl window in this case and probably would not fit the look of your clientele.
On your list, I prefer Marvin the best. If you haven't seen them, take a look at Kolbe and Kolbe as well. Very nice units.
Defog window recap greenmax General DIY Discussions 4 05-07-2010 05:00 PM
help need to know how to replace windows wrapped in drywall caide3 Carpentry 4 03-02-2010 12:41 PM
Problem with window and everything around it malfunction Building & Construction 3 05-26-2009 05:11 PM
Vinyl replacment window gap CowboyAndy Remodeling 3 03-26-2008 06:01 PM
