Bay Window Support Braces - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 09-09-2011, 08:51 AM   #1
Rewards Points: 165
I will be installing a new bay window in an opening that currently has a larged multi-pane window in it alrealdy. My question on this install has to do with how to support the bay window once it is installed. Underneath where this window is, is a cast iron convector set into the wall. There are no cripple studs across the span under the window framing due to the radiator being set back. So how am I supposed to brace the bottom of the bay window if there is nothig the brace it to? Thanks.
chronojosh is offline   Reply With Quote
Old 09-09-2011, 08:55 AM   #2
DIY staff
Rewards Points: 7,174
Most bay windows are actually hung by adjustable cables--attached to the rafter tails--so no support under the window is needed.
Old 09-09-2011, 09:59 AM   #3
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 3,036
How big is the bay window going to be.
Turn buckles are commonly used to tie in to the rafters as mentioned.
Old 09-09-2011, 12:48 PM   #4
Rewards Points: 165
The window frame is approximately 5' x 5'. I'm not home so I don't have the exact dimensions. I thought that the turnbuckles may be the case, and that's fine. The window will be under a large eave, so there is plenty of support to tie into, but I thought that you use turnbuckles and supports underneath. Thanks again for the info.
Old 09-09-2011, 12:57 PM   #5
DIY staff
The 'supports' under the window are strictly decorative when you use a cable system.
Old 09-09-2011, 12:58 PM   #6
Home Performance
HomeSealed's Avatar
Rewards Points: 712
The turnbuckle systems come with vitually all new bay windows. Be careful though, as some manufacturers call for both. I personally don't think both are necessary, but you would not want to void the warranty.
Replacement Windows, doors, siding, roofing, insulation, and BPI certified energy consulting, Building Analyst 5051322
www.HomeSealed.com
Replacement Windows Milwaukee
HomeSealed is offline   Reply With Quote
The Following User Says Thank You to HomeSealed For This Useful Post:
oh'mike (09-09-2011)
Installing a Replacement Vinyl window with brick mold jlatulippe Carpentry 4 06-23-2011 02:05 PM
In-swing non-crank casement window screen blee Windows and Doors 2 05-21-2011 02:42 PM
How to 'finish' outside of replacement window? KatieAK Building & Construction 9 04-02-2010 06:37 AM
help need to know how to replace windows wrapped in drywall caide3 Carpentry 4 03-02-2010 12:41 PM
Replace old window with smaller window Suncrest79 Building & Construction 3 04-15-2009 08:39 PM
