Bay Window - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 08-19-2012, 01:54 PM   #1
Question
Bay Window
Hey fellow DIYers,
I am new to the site and hope I can offer as much input as I need.
I have a Bay Window in front of split ranch which sts on the foundation and also protrudes from the house. The bottom has a 2 foot clearance outside and I notice the bottom is sagging( not thy window or frame itself. Can I repair that with plywood and maybe use some felt paper and then caulk it up. THANKS!
CedarNine is offline   Reply With Quote
Old 08-19-2012, 03:01 PM   #2
Rewards Points: 13,270
Going to need to post a picture.
Old 08-22-2012, 02:50 PM   #3
Home Performance
HomeSealed's Avatar
Rewards Points: 712
If only the seat board is sagging (not the entire unit) then you must have some water issues that should be addressed first... As for the repair itself, as Joe said, some pics would help tremendously in assessing that.
Replacement Windows, doors, siding, roofing, insulation, and BPI certified energy consulting, Building Analyst 5051322
www.HomeSealed.com
Replacement Windows Milwaukee
HomeSealed is offline   Reply With Quote
Old 08-22-2012, 10:42 PM   #4
AHH, SPANS!!!
Rewards Points: 1,166
is it the 2' soffit panel underneath of the bay window that is falling down?
hand drive is offline   Reply With Quote
Old 08-23-2012, 11:46 AM   #5
Cool
Exactly! Thank You
Old 08-23-2012, 01:32 PM   #6
AHH, SPANS!!!
Originally Posted by CedarNine View Post
Exactly! Thank You
Certainly You will need a tarp spread out on the ground to lay on and either try and re attach the panel or replace with a new one. if the panel is rotten or compromised causing it to sag then there is a leak from above somewhere at the bay window trim and that needs to be fixed first before the panel. The panel could be sagging from incorrect installation and just needs a few screws to hold it up. Before putting the panel back up and while you can see the bay window framing, check to make sure they insulated under the bay window and seal around the edges when you get the panel back into place
Old 08-23-2012, 02:43 PM   #7
Yes there was insulation and the water came from the gutters overflowing. Just bought the house and the gutters were clear. It was the leaders or downspouts that were clogged. Just want to know if plywood and felt would Brit good enough as that actual panel. Thanks again bro
Old 08-23-2012, 02:52 PM   #8
AHH, SPANS!!!
depending how close to the ground the underside of the bay window is will determine what to use under there, but in general I would use hardie panel or treated 1/2" plywood with exterior screws. felt paper installed to the framing before the panel goes up will not hurt either...
Old 08-23-2012, 05:42 PM   #9
Thanks hand drive. I have 2 feet to the underground. So felt paper first then 1/2 treated plywood with exterior screws. You are the man,and because of people like yourself and this chatroom,I will be getting a lot done. Over and out from NYC. Go MARK MARTIN.
Window Stool Removal Issue bperk21 Windows and Doors 4 04-21-2011 07:03 PM
Defog window recap greenmax General DIY Discussions 4 05-07-2010 06:00 PM
help need to know how to replace windows wrapped in drywall caide3 Carpentry 4 03-02-2010 01:41 PM
Problem with window and everything around it malfunction Building & Construction 3 05-26-2009 06:11 PM
