Bay Window - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 08-10-2012, 07:34 AM   #1
Cmh
Bay window
How do I defogg a bay window panel
Cmh is offline   Reply With Quote
Old 08-10-2012, 07:57 AM   #2
DIY staff
Rewards Points: 7,174
You need to get the panel replaced---any glass company should be able to provide that service.
joecaption (08-10-2012)
Old 08-10-2012, 09:15 AM   #3
Rewards Points: 13,270
Someone may suggest some magic quick fix, drilling a hole in the sash, using silicone ECT. none of which will work.
The seal is broken and there's no way to get the stains on the glass off.
Replace the whole thing and be done with it.
Old 08-10-2012, 10:18 AM   #4
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 1,834
Replace the IGU or drill some holes in it.
There are some "de-fogging" options out there as well but IGU replacement is the only real guarantee that the problem will be fixed and instantaneously.
Old 08-10-2012, 10:20 AM   #5
Joe,
If the homeowner catches the seal failure early and the glass does not stain, some of the de-fogging options (if done properly) do work. We don't do it, however, I have seen 5 year old de-fogged fixes done that still look clear.
Installing a Replacement Vinyl window with brick mold jlatulippe Carpentry 4 06-23-2011 03:05 PM
Defog window recap greenmax General DIY Discussions 4 05-07-2010 06:00 PM
help need to know how to replace windows wrapped in drywall caide3 Carpentry 4 03-02-2010 01:41 PM
Problem with window and everything around it malfunction Building & Construction 3 05-26-2009 06:11 PM
