Bathroom Window Trim - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 01-12-2012, 06:32 PM   #1
Bathroom window trim
My bathroom window in my shower has wood molding bordering the window. I bought composite wood molding what would the best way to install these? Will composite split if using a finishing nail?
Ckb3216 is offline   Reply With Quote
Old 01-12-2012, 06:36 PM   #2
Rewards Points: 13,456
Any window in a shower is a bad idea, there will be wall leakage at some point.
Composit can mean anything. What you should have bought is PVC, is this what you meant?
Old 01-12-2012, 06:36 PM   #3
Disabled wood vet
titanoman's Avatar
Rewards Points: 1,004
Yes. And...I'm not sure what you mean by composite...if you mean MDF (dense particle board) that will fall apart from the moisture.
Sent from a Samsung Galaxy S2
titanoman is offline   Reply With Quote
Old 01-12-2012, 06:42 PM   #4
Hmm do they sell pvc trim at a home depot??
Old 01-12-2012, 07:04 PM   #5
Home Performance
HomeSealed's Avatar
Rewards Points: 712
Yep... and its the only thing that should be used in a shower.
Finish nails will not split it. Just caulk the holes after nailing... You'll also want to caulk ALL seams and miters to mitigate leakage.
Replacement Windows, doors, siding, roofing, insulation, and BPI certified energy consulting, Building Analyst 5051322
www.HomeSealed.com
Replacement Windows Milwaukee
HomeSealed is offline   Reply With Quote
Old 01-12-2012, 07:05 PM   #6
Home Performance
HomeSealed's Avatar
Rewards Points: 712
"exterior use" finish nails would be ideal... Those are sold at HD as well.
www.HomeSealed.com
Old 01-12-2012, 08:18 PM   #7
Thanks!!
advice on bathroom window and makeover for bathroom charles101 Windows and Doors 11 04-10-2011 08:37 AM
How can I vent a bathroom exhaust fan out of the window without it looking hideous? mizrachi HVAC 11 12-01-2010 08:14 PM
Window Replacement and Trim Red Truck Building & Construction 3 02-11-2010 10:13 AM
restaining window trim ciera Painting 11 11-12-2007 01:29 PM
locate a vendor for vinyl window pane trim bjr23 Remodeling 1 02-13-2005 11:59 PM
