-   Windows and Doors (http://www.diychatroom.com/f104/)
-   -   Bathroom window trim (http://www.diychatroom.com/f104/bathroom-window-trim-129744/)
Ckb3216 01-12-2012 06:32 PM
My bathroom window in my shower has wood molding bordering the window. I bought composite wood molding what would the best way to install these? Will composite split if using a finishing nail?
joecaption 01-12-2012 06:36 PM
Any window in a shower is a bad idea, there will be wall leakage at some point.
Composit can mean anything. What you should have bought is PVC, is this what you meant?
titanoman 01-12-2012 06:36 PM
Yes. And...I'm not sure what you mean by composite...if you mean MDF (dense particle board) that will fall apart from the moisture.
Sent from a Samsung Galaxy S2
Ckb3216 01-12-2012 06:42 PM
Hmm do they sell pvc trim at a home depot??
HomeSealed 01-12-2012 07:04 PM
Yep... and its the only thing that should be used in a shower.
Finish nails will not split it. Just caulk the holes after nailing... You'll also want to caulk ALL seams and miters to mitigate leakage.
HomeSealed 01-12-2012 07:05 PM
"exterior use" finish nails would be ideal... Those are sold at HD as well.:thumbup:
Ckb3216 01-12-2012 08:18 PM
Thanks!!
