Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Windows and Doors
Old 11-19-2012, 10:52 PM   #1
Bathroom window that is over the tub/shower
What kind of material does the window frame need to be constructed of to make it waterproof? The current window is single-hung vertical 30x36, in an existing older home. I am remodeling and will be surrounding the window with a subway tile wall.
g martensen is offline   Reply With Quote
Old 11-19-2012, 11:08 PM   #2
Got a picture?
No a big fan of a window in a wet area, what's the first thing you do, add a curtain and close it.
Changing it to a transome style window will still give you light but non of the other issues like rot and possible wall damage.
Even a solor tube will light up a whole room.
A vinyl window and vinyl trim that get's caulked is about the best you can do if you want to keep the window there.
mae-ling (11-19-2012)
Old 11-19-2012, 11:33 PM   #3
As said windows in shower area are bad.
Yep as joe says
A transom wdw that is up high and only lets light in is better.
If wdw is going to stay use a vinyl window install properly with a sill pan.
Use vinyl trim, caulk behind it as you install it and caulk joints. also caulk wdw corners.
Also use a plastic shower curtain style curtain.
mae-ling is offline   Reply With Quote
Old 11-19-2012, 11:36 PM   #4
http://jamsill.com/
The box stores are not going to stock these but any real lumber yard will have them or can order one for you.
mae-ling (11-20-2012)
Bathroom window sill 1janski Painting 5 09-26-2012 04:50 AM
Advice on replacing Bathroom window (w/pics) jasesun23 Windows and Doors 16 02-19-2012 01:40 AM
How can I vent a bathroom exhaust fan out of the window without it looking hideous? mizrachi HVAC 11 12-01-2010 09:14 PM
where to put the bathroom window debd Remodeling 3 02-05-2010 12:05 AM
Bathroom ventilation / window privacy issue Michael Thomas General Discussion 10 05-26-2009 10:09 AM
