#1 |
Bathroom door always wants to close - Help?
I have a bathroom door that always wants to close. It can never stay in one position. What do I need to do in order for it to be balanced and stay in the position I put it in? Thanks again guys.
Lionel |
#2 |
Have you tried replacing the hindges with some heavier ones.
#3 |
Average Guy
A door, that does not stay in the position it was left in, is out of plumb. That means that the pins in the hinges are not located plumb with each other. Sometimes this is matter of loose screws on a hinge. Check that first. On that note, a door that swings close usually means the bottom hinge is loose and the door that swings open usually means the top hinge is loose. If the hinges are both tight, then the door was never hung correctly to begin with. This can be fixed by moving the hinges, but moving the hinges might cause other problems like the door won't close flush anymore. Start by putting a level on the hinge side of the door when the door is open perpendicular to the wall (the part that the hinges screw into). You may notice that the top of the door leans towards the jamb. If it is not plumb then you can move a hinge or both. Getting the two hinges in plumb with each other means moving the top hinge out or the bottom hinge in on the door jamb. If it is plumb with the door perpendicular to the wall, then you can probably fix the problem by shiming behind a hinge Open the door all the way and then check it with a level. Add a shim behind where the hinge attaches to the door jamb to get it level. Again this is putting a band-aid on the real problem. To get this absolutely correct, you should remove the trim around the door jamb and re-hang the door. But a little bit of hinge moving might do the trick.
My explanation may be confusing to read. If you have any questions just respond with more questions. Good luck, Average Guy http://www.averageguydiy.com |
| The Following 2 Users Say Thank You to mcruickshank For This Useful Post: | princelake (04-06-2012), sdsester (10-04-2012) |
#4 |
Contractor
mc has walked you through corrective procedures quite well. You're out of plumb.
#5 |
If the door is just slightly out of plumb--remove 1 hinge pin. Lay it flat on a hard surfice--hit hard with a hammer on the side of the pin to put a small bend in. Replace pin and the friction helps stop the swing.
#6 |
Thanks guys. Worked like a charm. I'm glad to be a part of this board!
#7 |
Idacpano,
What did you end up doing to fix the problem? Was it bending one of the pins or did you move one of the hinges? Thanks. -John |
#8 |
Ha ha... yeah, had two doors that have been driving me crazy for a couple of years now, always trying to close themselves. So I did the bent hinge pin suggestion, seems to be working, for now.
| Display Modes | |
| bathroom remodel complications | megancn | Building & Construction | 6 | 07-24-2012 05:38 PM |
| Duct Work For Bathroom | buildit45 | HVAC | 2 | 07-07-2012 10:36 PM |
| gutting bathroom | debiasio | Remodeling | 30 | 02-17-2011 03:32 PM |
| Bathroom leak? | sharp | General Discussion | 4 | 07-18-2009 09:54 AM |
| Larson Storm Door Won't Close | Snowbird | Building & Construction | 13 | 03-03-2009 04:01 AM |
