Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Windows and Doors
Old 07-23-2012, 09:26 AM   #1
Basement window replacement help
I know this topic has been done to death, but the frames that my windows are in dont seem to be like the ones most others have, so im curious what I am up against.
I have replaced all the windows in our house except the basement. All of those were in wood frames, and easy enough to do. These have me a little confused.
It looks like a four piece frame (t, b, left, right) with flanges on both sides of the foundation that recess into the wall. Im curious what it will take to remove the frame, and what I will have to do to prep for the new vinyl sliders.
From the outside, you can see the top flange is rusting away and has bent due to freeze/thaw. I have caulked it as a temporary measure until I had time to replace them.
From the interior, you can see the frame better
It looks like there were four pieces to the frame since they have flanges on both sides of the foundation. The metal seems to be about 1/8".
Whats the best way to remove these, and what will I be left with to prep for new windows? I dont want to use any sort of wood framing as these get pretty consistent south/west exposure and will be rained/snowed and in direct sun, etc.
redline9k is offline   Reply With Quote
Old 07-23-2012, 10:56 AM   #2
Exterior Construction
Windows on Wash's Avatar
Pull the whole steel frame, trim out in an Azek or PVC buck frame with some positive drainage, set in new vinyl slider, and seal up.
Old 07-23-2012, 11:04 AM   #3
Any tricks to pulling the frame? Are those frames set into wet cement or just sealed in place?
Im thinking the angle grinder at midpoint and then a large prybar should do it?
Once its out, i think im good, Im just trying to figure out what sort of damage im going to have to repair when i wrestle the frames out!
Old 07-23-2012, 04:44 PM   #4
No real tricks and each one is different. Thankfully, in this case, you don't need to re-use it so get to pulling, cutting, and smashing.
Old 07-23-2012, 05:55 PM   #5
Moderator
kwikfishron's Avatar
Sheesh...you can't give these guys all the good tricks of the trade.
-NEW MEMBERS-
Please include your basic location in your profile. Some of the answers given are specific to a Region or State.
kwikfishron is offline   Reply With Quote
Old 07-24-2012, 05:18 AM   #6
Very true.
While demo is a violent process sometimes, it is certainly not as it is glorified on TV where you are going through the sledge hammer and breaking stuff just to break it.
16x16 deck in front of basement window NickWa Building & Construction 5 03-23-2012 12:41 PM
Installing a Replacement Vinyl window with brick mold jlatulippe Carpentry 4 06-23-2011 03:05 PM
Window Pane Replacement rjschwar Building & Construction 3 08-27-2010 08:15 AM
Last minute Tips for Window Replacement? gmhammes Remodeling 20 08-17-2010 09:09 AM
Basement Window installation topher0524 Building & Construction 6 10-04-2009 05:46 PM
