Basement Window Leak - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 07-06-2012, 01:05 PM   #1
Basement window leak
Looking for some advice on how to fix this problem. Thanks in advance for your suggestions.
I am finishing the basement of a 5-year-old home. One of the basement windows is leaking (during heavy rain). The leak seems to be coming from either the concrete side or the window side of the 2 X 6 pressure treated casing. The issue does not seem to be the window itself, but rather the installation and/or sealing of window.
Note that the water is not pooling in the window well and the weeping tile is training as it normally should. The water is penetrating from angled rain or water running down the house.
I will upload some photos to help visualize the issue.
-kr
Basement window leak-insideside-window.jpg   Basement window leak-insidetopofwindow.jpg   Basement window leak-outsidephoto.jpg
alkr is offline   Reply With Quote
Old 07-06-2012, 06:26 PM   #2
kwikfishron's Avatar
Rewards Points: 210
Welcome to the forum.
A simple hose test should tell you the actual point of entry of the leak. From that we can decide on the best plan to solve the issue.
EDIT: I don't see any weep holes on that window.
kwikfishron is offline   Reply With Quote
Old 07-06-2012, 06:49 PM   #3
Rewards Points: 13,300
I do not see any nailing fin.
If it's a flat jamb window it should have been installed flush with the outside with trim around the window that covered about 1/2 of the window frame with silicone under the trim.
Old 07-09-2012, 12:01 AM   #4
Rewards Points: 1,442
I had the same issue. The caulk failed around the windows. Recaulked outside and spray foamed inside. It's poor installation, so if you feel like reinstalling the window, it would be a good thing.
mikegp is offline   Reply With Quote
How to - prevent basement mold crazymountain How To Guides 36 07-23-2014 07:02 PM
Window Leak: Flashing or Window? lverma Building & Construction 16 08-31-2010 01:46 PM
Can I build a wall over a window in basement? Rife Building & Construction 6 08-30-2010 07:40 PM
Basement window recessed in foundation Freaka Building & Construction 4 11-09-2008 07:15 PM
DIY Egress window in basement? ClnlBrahm Building & Construction 5 09-03-2008 12:15 PM
