Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Windows and Doors
Old 11-01-2012, 11:41 AM   #1
Basement door installation
I'm trying to figure out how to install an exterior door in my basement, once the basement wall is finished on the inside. The Basement wall is 8" Cement Block. I'm going to put 2" foam insulation and then 2x4 framing and drywall on the inside. This means my door frame opening will be about 14" deep. The door should open to the inside and sit flush with the interior wall. Can I get a door with a 14" Jamb? What are my other options?
mikeg_77 is offline   Reply With Quote
Old 11-01-2012, 12:42 PM   #2
Got a picture?
Just install jamb extention to the back side of the door, there is no need for a wider threshold.
Old 11-01-2012, 02:59 PM   #3
Just build jamb extensions.Can you sit the door to the outside of the wall than put jamb extensions or some kind of wood trim on the inside.
scottktmrider is offline   Reply With Quote
Old 11-01-2012, 03:36 PM   #4
If I do that the door will sit in the middle of the wall and will only open to 90 degrees, because it will hit the deep inset. It needs to set flush with the inside to open fully.
Old 11-01-2012, 03:54 PM   #5
The door will be installed so it's flush with the finished wall in the basement and swing into the basement, not in the middle of the wall.
Just buy a prehung door remove the casing on the back side.
Basement sewer smell jturk1000 Plumbing 1 09-20-2011 01:59 PM
Wet basement - don't know where to start konradsa Building & Construction 17 09-20-2011 11:08 AM
Remodeling basement: Moist foundation gordonf238 Building & Construction 8 04-25-2010 07:50 PM
Basement Renovation Project Howdy Electrical 6 03-13-2008 12:07 PM
Basement - need to bust up about 1 ft deeper FallenAngel Building & Construction 7 08-15-2007 10:09 AM
