Basement Door Doesnt Seal... - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 09-24-2011, 10:56 AM   #1
Basement door doesnt seal...
Hey everyone. I just bought a house. It was built in the 1940s. I live in southern Indiana. The problem is the basement door does not have a seal on the bottom so water just pours in when it rains. The door is steel and is not a normal size so the builders that remodeled the place cut the door so it is foam on the bottom. I need to find some way to create a seal. I am on a really tight budget so an inexpensive fix is much appreciated.
Here are some pics of the area.
Door closed
door open
bottom of door
Thanks in advance for any and all help.
Chad
chadepeters is offline   Reply With Quote
Old 09-24-2011, 08:13 PM   #2
kwikfishron's Avatar
Rewards Points: 172
You can install a door sweep on the bottom of the door but until you solve the real problem (water cascading down the steps) all of your efforts with the door will the fruitless.
The water has to go somewhere, you need to control it at the topside not the bottom.
kwikfishron is offline   Reply With Quote
Old 09-24-2011, 08:39 PM   #3
DIY staff
Rewards Points: 7,174
Look in the trash for the threshold that was removed when the door was cut and get that installed--along with the door bottom that Ron mentioned,
And install a drain---that's a door ,not a bulkhead so water will pass it.
Old 09-25-2011, 01:36 AM   #4
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 1,784
Until you fix the source of the water or control it, not much is going to work that effectively.
Old 10-04-2011, 10:01 AM   #5
Just install a drain or a passage to redirect the water first.
Basement Doors is offline   Reply With Quote
Old 10-04-2011, 02:59 PM   #6
Home Performance
HomeSealed's Avatar
Rewards Points: 710
One more vote for addressing the drainage issue... The threshold/sweep combo is a must though too, unless you don't mind mice, bugs, and a ton of air leakage.
Replacement Windows, doors, siding, roofing, insulation, and BPI certified energy consulting, Building Analyst 5051322
www.HomeSealed.com
Replacement Windows Milwaukee
HomeSealed is offline   Reply With Quote
Cutting out a concrete basement floor jeffhoward001 Building & Construction 21 01-17-2012 09:51 PM
Running from outside service panel into basement ksl420 Electrical 0 03-21-2011 12:30 PM
Over insulate basement? braverichard Building & Construction 26 06-22-2010 09:26 PM
Crawl Space In Basement -- Please Help thekid Building & Construction 7 01-04-2008 09:15 PM
Basement - need to bust up about 1 ft deeper FallenAngel Building & Construction 7 08-15-2007 10:09 AM
